Expansion Tank Missing - Plumbing - DIY Home Improvement | DIYChatroom
Old 01-09-2010, 06:00 PM   #1
expansion tank missing
my gas water heater has no expansion tank tho my furnace does. Is this a needed component and why? thanks Timothy
Old 01-09-2010, 10:58 PM   #2
Do something
D'Brie's Avatar
An expansion tank takes the excess pressure made by your water heater as it heats the water to your selected temperature. By having an expansion tank, your plumbing fixtures (especially toilets) will not have the effects of expasion pushing on their seals. It's a good idea to have one on your incoming cold line.
D'Brie is offline   Reply With Quote
Old 01-10-2010, 03:08 AM   #3
Rewards Points: 150
you need an exp.tank if there is a back flow preventer,pressure reducing valve,check valve or dual check valve at your meter on the main water to your house.
rudolph58 is offline   Reply With Quote
Old 01-10-2010, 07:46 AM   #4
thanks, have well
Old 01-10-2010, 10:59 AM   #5
Rewards Points: 150
about 1 extra gal. of water is produced in a 40 gal.water heater when the water is heated I believe 30 deg.above the in coming water temp.
Old 01-10-2010, 09:53 PM   #6
Rewards Points: 171
If you have a well then you already have an expansion tank. Its the tank connected to the well.
paul100 is offline   Reply With Quote
Old 01-10-2010, 10:10 PM   #7
Rewards Points: 150
just thought i would quote him something i heard at my continuing ed.class.
Installing a new boiler expansion tank CoachDad HVAC 0 01-06-2010 01:12 PM
Pressure relief leaking and expansion tank full themow HVAC 1 11-25-2009 04:49 PM
Expansion tank location?? rcassidy HVAC 4 10-06-2009 09:01 AM
Installing new expansion tank ted schumm HVAC 2 07-19-2009 09:49 PM
No Expansion Tank for Water Heater vasanvasan Plumbing 4 12-13-2007 11:16 PM
