Expansion Tank Location - Plumbing - DIY Home Improvement | DIYChatroom
Old 10-20-2011, 04:37 PM   #1
Smile
expansion tank location
I am planning on putting an expansion tank in my residential home water system but I am constrained in location close to the water heater. It currently does not have one. How far away in the cold water line can an expansion tank be placed. It would be very convenient to install almost immediately after the pressure reducer at the inlet to the house. This is probably 40 feet as the water flows to the water heater.
Rankid is offline   Reply With Quote
Old 10-20-2011, 06:31 PM   #2
Rewards Points: 1,214
That's where mine is for 21 years no problems. Before that the hot water relief valve kept weeping.
COLDIRON is offline   Reply With Quote
The Following User Says Thank You to COLDIRON For This Useful Post:
Rankid (10-20-2011)
Old 10-21-2011, 07:37 AM   #3
Rewards Points: 1,418
An expansion tank can go anywhere in the plumbing system but it is better if the expansion tank is placed so there is no valve of any kind between it and the water heater and also so that anyone inspecting the water heater can see that an expansion tank exists.
Old 10-21-2011, 11:33 PM   #4
Thanks for the responses. I am planning on putting the tank in the convenient spot, which is also easily visible in the basement - different room but will be obvious.
Mounting of HWH expansion tank steve0617 Plumbing 4 01-17-2011 01:44 PM
Moving Expansion Tank C_J_GO Plumbing 1 01-09-2010 06:56 PM
Toilet jpark Plumbing 18 01-05-2009 08:12 AM
will a expansion tank help with water hammer wazeaz Plumbing 3 07-13-2008 12:51 AM
Upstairs toilet pipe noise bliss Plumbing 8 01-10-2008 08:55 AM
