Expansion Tank For 40 Gal Gas Water Heater - Plumbing - DIY Home Improvement | DIYChatroom
Old 11-02-2011, 02:59 PM   #1
Rewards Points: 1,062
Question
expansion tank for 40 gal gas water heater
i was wondering if this is an adequate expansion tank for a 40 gal gas water heater:
http://www.houseneeds.com/shop/flexc...-htx30-buy.asp
or this:
http://www.amazon.com/Flexcon-PH12-E...0264266&sr=1-2
I am skeptical about the former cause it says "closed loop". that's the one i have for my closed radiator system and water heater system isn't closed, i guess. so maybe the latter.
thanks
Old 11-02-2011, 04:00 PM   #2
raylo32's Avatar
Rewards Points: 1,294
They look essentially the same but I'd go with the one spec'ed for potable water systems (the one linked on Amazon). Maybe the membrane is made of material certified to not leach anything into potable water supply whereas that may not be the case for the other one. Good to see you going with the 4.5 gal size. You could technically use the 2 gal size with a 40 gal water heater but with these the bigger the better as in less pressure rise as the water heater heats up.
raylo32 is offline   Reply With Quote
The Following User Says Thank You to raylo32 For This Useful Post:
amakarevic (11-03-2011)
Old 11-03-2011, 07:12 AM   #3
Rewards Points: 1,216
Installed one half the size 20 years ago on my cold water inlet from the street never had a problem since then. Problem was water heater relief valve weeping due to no expansion capability.
COLDIRON is offline   Reply With Quote
The Following User Says Thank You to COLDIRON For This Useful Post:
Old 11-03-2011, 11:12 AM   #4
raylo32's Avatar
I understand the codes in most places call for exp tanks on new construction. My place built in 1995 did not have one. After I was there for a year or 2 I installed a pressure gage and watched system pressure during a water heater heat up cycle. It got to well over 100 psi. And that wasn't even a "design basis" transient that would occur with heating up an entire tank of water from stone cold winter inlet temps. Yikes! I went out and got a tank that week from Lowes and installed it. No need to have every water heater cycle do a system hydrostatic test!
replacing hot/cold water lines ontop of hot water heater tank rickwest59 Plumbing 10 10-11-2011 08:09 PM
Installing an expansion tank Homerepairguy Plumbing 1 01-25-2011 08:10 AM
Pressure drop across water heater, low hot water flow HVAC_NW Plumbing 2 01-17-2011 10:43 PM
Hot Water Tank and Pressure Help tbakbradley Plumbing 2 01-17-2011 09:25 AM
