Expansion Tank - Plumbing - DIY Home Improvement | DIYChatroom
Old 02-10-2015, 04:23 PM   #1
Rewards Points: 40
Expansion tank
New to the site and really appreciate your professional imput.
I'm having a home built in a subdivision here in Ohio. A friend of mine already had 1 built last year. I was looking at his home and noticed something about his expansion tank for his gas water heater. I 'm not a fan of cpvc anyway but thats whats holding the tank in place. I attached pictures of the setup. Expansion tank laying on its side on top of water heater connected with cpvc. Is this code or am I over reacting to accidents that I think can happen with this.
Big Cat is offline   Reply With Quote
Old 02-10-2015, 04:32 PM   #2
Rewards Points: 252
I don't know if its code or not,
One of the plumbers will be along shortly to let you know.
If the expansion tank fails, you dont want the weight of the expansion tank to depend on the cpvc . However, In this case it is resting on the tank for support.
For safety, i would still strap it better. They can be very heavy when full of water. Just a suggestion.
jmon is online now   Reply With Quote
The Following User Says Thank You to jmon For This Useful Post:
Big Cat (02-10-2015)
Old 02-10-2015, 05:34 PM   #3
Rewards Points: 1,866
The expansion tank is supported by the Hot water tank, Not how I would do it but to code. It also ties into the cold inlet that's to code. Only thing I would add is a strap to the tank to hold the expansion tank in place. Use plastic hole strap and 2 small sheet metal screws.
Not a good job I have seen much better but as an inspector if it meets code we are not allowed to grade workmanship.
Old 02-10-2015, 06:00 PM   #4
Rewards Points: 582
well I respect you ghost....but that is a piss poor job imo .. I would fire anyone of my men if they did such a job..when they introduced those tanks i believe they wanted them in the verticial position supported on both sides of the tee holding them... while they may have changed some it still is the best way to install them ..either hanging down or mounted upright supported properly so if they fail.... and they will.... it won't cause any damage... I know inspectors don't grade work..but please be one of those guys that speak up to plumbers when they fail to use common sense....ben
The Following User Says Thank You to ben's plumbing For This Useful Post:
TheEplumber (02-10-2015)
Old 02-10-2015, 06:06 PM   #5
Plumber
TheEplumber's Avatar
Rewards Points: 562
There is a bracket out there made for just this situation. You can hang it vertically or horizontally from a joist- not bad priced either.
Or a simple drop ear attached to the joist......
It would really clean that up
http://holdrite.com/product/qs-5/
The Following 2 Users Say Thank You to TheEplumber For This Useful Post:
ben's plumbing (02-10-2015), Big Cat (02-10-2015)
Old 02-10-2015, 06:08 PM   #6
If you look at your expansion tank install sheets a horizontal placement is fine. It has to be supported. Like I said it's not what I would do but it does meet the code sections I can apply. I'm not allowed to grade workmen ship because that leads to a lot of issues.
What we look at is code. Is an expansion control device required? If so it can be installed any where in the house on the cold water. (little known fact)
If installed horizontally is it supported per manufacture install instructions. In this case it is.
I would also fire my employee if he did a job like this for wasted materials and gross stupidity. But I can't because no code violation exist. You do not want plumbing inspectors drifting away from the code and enforcing stuff they like. Soon enforcement will not have a resemblance of code. It will just be what one guy thinks it should be. That's not good either.
The Following 3 Users Say Thank You to Ghostmaker For This Useful Post:
ben's plumbing (02-10-2015), Big Cat (02-10-2015), MHElectric (02-15-2015)
Old 02-10-2015, 06:12 PM   #7
I have one shop out of 100 that installs that strap for the tank. What does that tell you about that one shop?
Old 02-10-2015, 06:27 PM   #8
Rewards Points: 582
sorry for wasting time.....
Old 02-10-2015, 06:33 PM   #9
Ben you can install them horizontal with support also. It's common for small tanks. Most run strapping around tank to the joist above.
All the support is for is when the bladder blows a hole.
Old 02-10-2015, 06:40 PM   #10
Rewards Points: 582
yep i know it can be installed either way with proper support...what iam saying is the manufacture in it installation instructions say ..its designed to be installed in the verticial position......don't shoot the messenger
Old 02-10-2015, 07:01 PM   #11
Rewards Points: 582
when i install any product . I was trained to install according to manufacture instructions cuppled with the local plumbing/ buliding codes which ever applies ...if that passed inspection by code ...which it did ..it would be void of warranty from manufacture....just saying...
Old 02-10-2015, 08:43 PM   #12
Rewards Points: 40
Thanks for your replies. I figured code would require some kind of support to secure it in place. With that cpvc holding it in place, it just a accidental bump from a disaster. Hopefully I get the same plumbing contractor who did the model home. I do see where the vertical install whould be smart so all the water can drain from the tank when not needed. I may look into buying a support and try to be there and give it to the plumber. Wouldn't want anyone to get fired for spending their bosses money
Old 02-10-2015, 10:18 PM   #13
Rewards Points: 582
imho ..I would want that changed...I can't believe a plumber did that...:furiou s:
Old 02-11-2015, 06:37 AM   #14
Rewards Points: 1,494
Is that expansion tank tethered so it could not slide off of the top of the water heater?
The Following User Says Thank You to AllanJ For This Useful Post:
Big Cat (02-11-2015)
Old 02-11-2015, 06:56 AM   #15
Lord of Slums
Rewards Points: 1,974
From what I have seen in the last few years this is a great job. I am fairly sure their is an elementary school here in town that has field trips where the kids go into people's homes an install water heaters.
mj12 is offline   Reply With Quote
The Following User Says Thank You to mj12 For This Useful Post:
Expansion Tank jagans Plumbing 12 06-03-2013 12:29 PM
Question re draining heating expansion tank Rav HVAC 4 11-19-2012 09:53 AM
Expansion tank size problem Austin83 Plumbing 7 11-16-2012 07:58 AM
Old expansion tank leaking Ultrarunner2017 HVAC 7 11-16-2011 06:40 AM
Is a Hot Water Expansion Tank required Needagameplan Plumbing 9 04-27-2010 03:09 PM
