Old 06-13-2012, 11:49 AM   #1
Expansion Tank
Do I need an expansion tank for my hot water heater. I have a back flow device that is T'd off of the main water line. I need to change my hot water heater and I am not sure if I need to have a domestic water expansion tank installed.
staycee is offline   Reply With Quote
Old 06-13-2012, 11:58 AM   #2
Expansion Tank
Yes, the water will need somewhere to expand, since the backflow device won't allow it to push back outside. If you dont, your commode fill valves may leak the pressure off, but it will wear on all of your valves.
TopTechnician is offline   Reply With Quote
Installation and support of water heater expansion tanks. Homerepairguy Plumbing 46 01-28-2013 06:55 AM
Expansion Tank Electric Hot Water dougp23 Plumbing 1 12-27-2011 08:27 AM
Septic tank missing T and badly angled main line? denemante Plumbing 3 11-22-2011 10:29 AM
Installing an expansion tank Homerepairguy Plumbing 1 01-25-2011 09:10 AM
Installing a new boiler expansion tank CoachDad HVAC 0 01-06-2010 02:12 PM
