Ever Seen A Toilet Rough In Like This? - Plumbing - DIY Home Improvement | DIYChatroom
Old 12-24-2011, 11:21 PM   #16
Missouri Bound's Avatar
Originally Posted by joecaption View Post
I was hoping some of the plumbers on here would chime in. Wht's is that drain line sitting againt the block wall for?
Where's the vent for the toilet and drain lines for the sink?
The pipe on the back wall is the vent and the sink drain line.
Old 12-24-2011, 11:25 PM   #17
Rewards Points: 13,694
What size pipe is it?
Old 12-24-2011, 11:58 PM   #18
Plumber
TheEplumber's Avatar
Rewards Points: 664
You answered your own question.
The 2" pipe is the wc vent. The 1.5" horizontal line is for the lav. It drains into the wc vent- AKA, a vertical wet vent.
The Following User Says Thank You to TheEplumber For This Useful Post:
ben's plumbing (12-25-2011)
Old 01-18-2012, 04:00 PM   #19
Rewards Points: 18
I'm guessing the drain line against the block wall is for your sink and above the "tee" is its vent line. Not sure where the vent for the toilet is, can't see through concrete.
Sdeclara is offline   Reply With Quote
Old 01-18-2012, 04:36 PM   #20
Rewards Points: 672
I'm thinking that should have been boxed in and not fully cemented in. Sticking up that far, and then the need for a flange on top, may bring you too high.
If this is the case, you may have to bust out the concrete to get things to fit perfectly.
Question: should the toilet flang sit ON TOP of the tile, or be Flush with the tile?
B
Beepster is offline   Reply With Quote
Old 01-18-2012, 07:40 PM   #21
Flange should sit on top.
Old 01-18-2012, 08:41 PM   #22
Plumber
Rewards Points: 664
B
I won't bite on this one............Next, someone will ask if a toilet should be caulked
Old 01-18-2012, 09:59 PM   #23
noshoff
I'm not a "pro" but the size of the toilet bottom may not be as important as the center of the drain being 15" from the finished wall. I'm pretty sure that's code around here!
shadowbuilder is offline   Reply With Quote
Old 01-19-2012, 08:18 AM   #24
Rewards Points: 150
B
This has come up alot lately, and although Eplumber doesn't want to bite, the consensus from most of the pros is "level with finished floor. I would set the flange in dry, then tile around it, then you can set the flange for finished floor elevation.
Do you mean from the back or laterally? Typical offset for flange is 12" from the back. 15" may be the lateral offset from a wall.
psilva8 is offline   Reply With Quote
Old 01-19-2012, 08:20 AM   #25
JOATMON
ddawg16's Avatar
Rewards Points: 1,812
No No.....not again......
I thought it was 12.1256"?
ddawg16 is online now   Reply With Quote
Help me check my logic on clogged drain and overflowing toilet Southlake_Ed Plumbing 10 01-05-2010 07:52 PM
Basement Toilet Rough In - Help atm Plumbing 3 06-06-2009 11:04 AM
Replace a 10" rough in toilet with a 12" rough in Opie46 Plumbing 3 05-16-2009 11:27 AM
Toilet jpark Plumbing 18 01-05-2009 07:12 AM
Move basement toilet rough in 6-8" HVACman Plumbing 5 04-19-2008 07:45 PM
