Ever Seen A Toilet Rough In Like This? - Plumbing - DIY Home Improvement | DIYChatroom
Old 12-24-2011, 05:14 PM   #1
Ever seen a toilet rough in like this?
I recently moved into a newer house (built in 2004) starting to research / planout finishing my basement. There is a complete rough in for a full bathroom. Attached is a pic of the toilet rough in. Has anyone ever seen one like this? Any suggestions on how the flange would attacbh to it?
Ohio_Matt is offline   Reply With Quote
Old 12-24-2011, 05:34 PM   #2
Rewards Points: 916
Is that pipe, an elbow, or a "tee"?
I would attach the flange with glue and anchor it down to the floor as well.
cleveman is offline   Reply With Quote
Old 12-24-2011, 05:57 PM   #3
Rewards Points: 582
thats a hub from a pvc fitting ...need to glue in a plastic flange then anchor to concrete....what is going on floor.....tile? if so install tile 1st then flange....
Old 12-24-2011, 06:00 PM   #4
Yes ultimately tile will be laid. It seems there are different types of flanges. I am guessing that the flange I need will glue to the inside of this pvc pipe?
Old 12-24-2011, 06:04 PM   #5
Rewards Points: 582
yes it looks like 4" pvc can't really tell so you would need 4"pvc spigot flange....that means it slips into a hub...ben
Old 12-24-2011, 06:06 PM   #6
Thanks for the help Ben. My last basement bathroom renovation already had the flange in place so I didn't have to worry. Thanks for your assistance!
Old 12-24-2011, 08:16 PM   #7
Rewards Points: 582
welcome and good luck on your project...
Old 12-24-2011, 10:33 PM   #8
Rewards Points: 12,790
What is the distance from the center of that drain pipe to the wall?
Where's the supply line for the toilet?
Not sure how they could have known where to place the drain unless they knew where the finished wall was going to come out.
Old 12-24-2011, 10:37 PM   #9
I checked all of that too. The center of the pipe is 18" from the cinderblock. With the finished wall being a maximum of 4" plus spacing so its not right against the cinderblock, I should have plenty of room for a 12" base toilet. Obviously I will need to run a supply line and stub out once the studs are in place, so all should be well.
Old 12-24-2011, 10:38 PM   #10
Tileguy
Bud Cline's Avatar
Rewards Points: 558
Sumpin' isn't right with all that !!!
XXX
Old 12-24-2011, 10:44 PM   #11
The other consern I'd have if the plan is to go with tile is is the expantion seam right there and the crack in the concrete. Yor going to have to lay some form of membrane on the floor first before the tile.
I'm not at home right now and using someone eles computer so I do not have the brand name right now. It's something like Detra. I'm sure one of the tile guys will get back to you soon and give you at least two choises on ways to fix this.
I found it.
http://www.schluter.com/6_1_ditra.aspx
Old 12-24-2011, 10:47 PM   #12
Bud do you see a potential problem that I might run into? If I'm not seeing something that I should be please point it out. I'm a novice DIYer but this isn't my first project either. I've done quite a bit actually.
Old 12-24-2011, 10:49 PM   #13
I was worried about that too Joe! Thanks for the tip. Any tile guys out there I'm all ears! If there is some sort of special product for me to put into that channel is love to hear suggestions!
Old 12-25-2011, 12:12 AM   #14
Missouri Bound's Avatar
You can adjust that wall width if need be, at least in the bathroom area. Looks like it was roughed in with a 6" wall in mind. By the time you insulate the block and stud it up you should be fine. Just get the stool and be sure of the rough in spacing. It's almost always 12"...but there are exceptions. And you may be able to use an offset flange although it may need a bit of "demo"
Old 12-25-2011, 12:18 AM   #15
I was hoping some of the plumbers on here would chime in. Wht's is that drain line sitting againt the block wall for?
Where's the vent for the toilet and drain lines for the sink?
Help me check my logic on clogged drain and overflowing toilet Southlake_Ed Plumbing 10 01-05-2010 08:52 PM
Basement Toilet Rough In - Help atm Plumbing 3 06-06-2009 12:04 PM
Replace a 10" rough in toilet with a 12" rough in Opie46 Plumbing 3 05-16-2009 12:27 PM
Toilet jpark Plumbing 18 01-05-2009 08:12 AM
Move basement toilet rough in 6-8" HVACman Plumbing 5 04-19-2008 08:45 PM
