Ever Hear Of This? - Plumbing - DIY Home Improvement | DIYChatroom
Old 03-19-2009, 03:46 PM   #1
Ever hear of this?
Brand new Kohler toilet installed with new pvc soil line and floor flange. After about 2 weeks I noticed a stain on the ceiling tile below the toilet. I saw a very small drop of water on the elbow and traced it to where the floor flange attaches to the ell. I used a flux brush to apply more glue around the seam and I thought I got it. But after about 6 hours a little drop appears. It does not leak when flushed I made sure to check on that. Has anyone ever heard of this? Any ideas for a fix?
hompac is offline   Reply With Quote
Old 03-19-2009, 09:38 PM   #2
HVAC / Plumbing
Did you clean & prime the pvc b-4 you installed the flange ?? Only fix I know is to take it off clean & prime & use plenty of glue
kenmac is offline   Reply With Quote
Old 03-20-2009, 09:00 AM   #3
you are saying you leak with out use the flusher . make sure the bowl is sealed to the closet flange . did you use a wax gasket ? how low is the flange? did you screw the flange to the floor ? and last the bowl is tight to the closet bolts? check all these .if a little drip comes out of the horn of the bowl it will run on the pipe ,making it look like the pipe is leaking , if the pvc is not sealed use silicone .
metx is offline   Reply With Quote
Old 03-20-2009, 10:39 AM   #4
Rewards Points: 1,442
A small leak might not drip until several minutes or maybe an hour after the last flush. It depends on exactly where water accumulated on the inside on pipe edges and rims. A single layer strip of toilet paper pressed here and there is an effective telltale indicator of where water is coming from given very small drips.
Old 03-20-2009, 11:33 AM   #5
Using glue to repair leaks on PVC is usually futile. You may want to remove the toilet, clean and thoroughly dry the area (with a blow dryer) and use 100% silicone all the way around the inside where the pipe and flange meet.
If you have never made a mistake, you haven't done much.
majakdragon is offline   Reply With Quote
I hear a drip upstairs before heater turns on diyraleigh HVAC 2 02-17-2009 03:44 PM
Why do i hear the water in my heating pipes? CMG Plumbing 3 12-09-2008 12:33 PM
I hear the water running in my heating pipes CMG HVAC 3 12-08-2008 07:46 PM
I hear water running through the pipes, but... DIYtestdummy Plumbing 17 10-29-2008 11:01 PM
Hear a Banging Noise from Bathroom Fan When its Windy wjk7320 Building & Construction 13 09-12-2007 11:13 PM
