Evenly Splitting Water Down 4 Lines - Plumbing - DIY Home Improvement | DIYChatroom
Old 11-26-2011, 05:29 PM   #1
Rewards Points: 264
Evenly splitting water down 4 lines
Lets say you have a pump and are wanting to pump an even (or close) amount of water down 4 separate tubes. What is the best way to do this without sacrificing much pressure?
tibberous is offline   Reply With Quote
Old 11-26-2011, 05:51 PM   #2
I would make a header and each branch would have a ball valve so you could throttle it down. Of course if you use it alot the balls in the ball valve would wear. Technically I think you would need a "globe" valve- it has a rubber washer like old school faucets.
broox is offline   Reply With Quote
replacing hot/cold water lines ontop of hot water heater tank rickwest59 Plumbing 10 10-11-2011 09:09 PM
Hot Water in Cold Water Lines ??? Superbuuck Plumbing 14 08-29-2011 01:21 PM
Solar hot water indatom123 Green Home Improvement 0 12-19-2010 01:01 AM
correct size pipe for water lines jce Plumbing 2 04-11-2010 09:23 PM
low hot water pressure angus242 Plumbing 10 01-08-2009 12:41 PM
