Estimating Flange Height For Rear Outlet Toilet - Plumbing - DIY Home Improvement | DIYChatroom
Old 07-03-2010, 09:43 AM   #1
Knows everything but that
Rewards Points: 150
estimating flange height for rear outlet toilet
Im soon going to be installing a rear outlet, floor mount toilet in my new bathroom. I have all of the walls up except for the ones where the toilet plumbing is going to go. Is there a way to estimate how tall I need to make the flange for the rear outlet? I have the subfloor down but am going to be installing Ditra and then porcelain tile. Id imagine that the flange needs to be the perfect height so that it seals correctly. I also think I should have the walls up, mudded and painted before I put a toilet in the way but Im not sure how to make the measurements right. Does anyone have any experience installing rear outlet toilets before the room is done? Thanks so much!
Shane
JakAHearts is offline   Reply With Quote
Old 07-03-2010, 01:43 PM   #2
DIY staff
Rewards Points: 7,174
Flange height is usually 4" center from finished floor---Check your manufacturers specs.
Will the wall be open behind the toilet after the floor finish is in?
That would be nice--Kind of a lot to hope for.--Mike--
Old 07-04-2010, 09:08 AM   #3
The information should be included in the toilet installation instructions. Guessing is not an option here.
If you have never made a mistake, you haven't done much.
majakdragon is offline   Reply With Quote
The Following User Says Thank You to majakdragon For This Useful Post:
oh'mike (07-04-2010)
Old 07-04-2010, 09:44 AM   #4
Rewards Points: 150
Right, but my floor isnt in yet. Neither are the walls. Im trying to put in the walls before the flooring and obviously need to install the plumbing before the walls. Maybe I should have asked this in the flooring section? Thanks anyway for the responses.
Old 07-04-2010, 10:00 AM   #5
The floors do not need to be installed, to measure the materials and see how much space they take up.
Old 07-04-2010, 12:39 PM   #6
Rewards Points: 150
Ok, I just thought with two layers of thinset going down I didnt know if that would be accurate enough just measuring the material.
Old 07-04-2010, 04:53 PM   #7
Well, then a guess at how thick you will spread the thinset is in order. You know the notch size of the trowel, so cut it in half (to allow for the pressing down of the tile). Closest you are going to get. I really wish you luck with your project, and I think it will all work out.
Toilet wax rings - plain wax? reinforced? with/without flange? How do you decide? lazzlazz Plumbing 0 05-16-2010 11:10 PM
Just for fun Andy in ATL Electrical 56 10-20-2009 09:33 AM
Toilet Flange Problem - New Tile Floor w/ Ditra qwkslvr Flooring 4 10-14-2009 10:04 PM
Broken toilet flange - concrete floor rob1 Plumbing 5 09-20-2009 10:45 AM
Toilet closet flange kensington Plumbing 5 04-27-2008 08:19 AM
