Epoxy For Very Minor Pipe Joint Drip? - Plumbing - DIY Home Improvement | DIYChatroom
Old 12-01-2009, 09:00 PM   #1
epoxy for very minor pipe joint drip?
Water heater joint drips one drop per minute. Is there an epoxy to seal a small drip..? Surface will be wet or moist.
Any ideas..?
tbass is offline   Reply With Quote
Old 12-01-2009, 09:26 PM   #2
ArmchairDIY's Avatar
It depends on where its dripping from. It may be rusting through and the drip could be a small sign of bigger things to come.
What area is the drip coming from?
Edit: I guess I need to learn to read more carefully I just noticed you said "joint"
Then I have to ask what type of joint? Copper, pvc, pex?
"It looked good on paper, but paper is funny that way"
Time to Get Up Out of Your Chair and Do it Yourself! ArmchairDIY.com
ArmchairDIY is offline   Reply With Quote
Old 12-02-2009, 07:46 AM   #3
Joe F's Avatar
Rewards Points: 294
I'll add to the questions: sweat, threaded, union?
If you don't stand behind our troops, please feel free to stand in front of them.
Joe F is offline   Reply With Quote
How To Solder Copper Pipes Termite How To Guides 69 11-13-2012 01:20 PM
Joint compound to smooth old paint layers. gmhut Painting 1 05-03-2009 06:50 PM
Shingle Installation with F5S Standard Drip Edge ShortEdged Roofing/Siding 32 02-15-2008 03:10 PM
Painted Tub With Epoxy, Didn't work.. Need your advice diyfan902 Painting 1 03-11-2007 04:55 PM
PVC drain pipe leaking at joint, 2 part epoxy last? harleysilo Plumbing 3 09-26-2006 01:29 PM
