Enough Space For Garbage Disposal And Deep Sink? - Plumbing - DIY Home Improvement | DIYChatroom
Old 01-04-2012, 10:04 PM   #1
Enough Space for Garbage Disposal and Deep Sink?
So I'm remodeling the kitchen ... just finished putting in the cabinets, getting ready to install the countertops. I'm looking at sinks to purchase and thinking about getting a deeper one, like 9-10 inches. But I'm wondering if a sink that deep will fit with the garbage disposal I already bought, which is fairly large. Here's the dimensions:
Garbage disposal height - 16 & 1/16
Internal height of cabinet - 28 & 3/4
So this leaves 12 & 11/16 of space, which is obviously more than a 10 in sink, but is that enough for the pvc fittings as well? Will a deeper sink fit or should I focus on a standard 8" depth?
jmai14 is offline   Reply With Quote
Old 01-04-2012, 10:08 PM   #2
jproffer's Avatar
Rewards Points: 706
So basically you have 2 11/16" for the sink basket and coupler?
It'd be tight, but I think it would make it.
Be aware: I don't have a GD, so I have nothing to measure to make sure.
jproffer is offline   Reply With Quote
Old 01-04-2012, 10:22 PM   #3
Plumber
TheEplumber's Avatar
Rewards Points: 452
What elevation is your drain at the wall?
How far down the disposal is it's outlet?
The Following User Says Thank You to TheEplumber For This Useful Post:
plummen (01-04-2012)
Old 01-04-2012, 10:36 PM   #4
TheEplumber -- The sink is actually in an island, so the drain goes straight through the floor. The discharge elbow piece of the garbage disposal is 7.25" from the top of the disposal to the center of the elbow. The elbow itself is 1.5" wide.
Old 01-04-2012, 10:44 PM   #5
Plumber
Rewards Points: 452
So, if I did my math right- you'll be about 11" above the cabinet base to the center of the disposal outlet. that should be enough room, although it will be tight.
ben's plumbing (01-05-2012)
Old 01-05-2012, 08:56 PM   #6
Rewards Points: 582
yes if my math is also correct you have enough room.....yes it will be tight
Tags
garbage disposal , kitchen remodel , plumbing , sink
Extra deep sink not working with disposal cWilson Plumbing 3 11-22-2010 12:55 PM
Sink Depth dilemna Yippee Plumbing 9 01-01-2008 01:25 PM
