Enlarging Vanity And P Trap Problems - Plumbing - DIY Home Improvement | DIYChatroom
Old 05-09-2011, 08:55 AM   #1
Enlarging vanity and P trap problems
Hi I remodelling a bathroom that currently has a 36 inch vanity and appropriate draining, water connections etc with which I haven't had any trouble. I'm thinking of enlarging the vanity to a 42 inch which means that my drain connection will move by 3 inches to one side (increase in vanity by 6 means a 3 inch move, right?).
At any rate, I'm concerned that enlarging the vanity will mean the drain won't work well. More to the point, is there a simple way to connect the P-drain to the vent if the vanity has moved? I plan on using PVC piping.
I'm looking to hear your opinion. Thanks in advance!
W
wildcard585 is offline   Reply With Quote
Old 05-09-2011, 09:22 AM   #2
MikeKy55's Avatar
Rewards Points: 254
Just a DIY'r here, but that shouldn't be difficult. Post a picture of the current configuration and someone can better advise.
MikeKy55 is offline   Reply With Quote
Old 05-10-2011, 07:34 AM   #3
Plumb or Die!
Should be an easy move. Likely you will add a 45 degree elbow on the horizontal part of the existing sink drain for the 3" offset.
plumber666 is offline   Reply With Quote
Building HVAC vent into bath vanity nolamar Carpentry 31 08-25-2011 02:33 PM
small gap between vanity and wall, how do i screw it in? cantgetenuff Building & Construction 8 03-09-2011 11:15 AM
How to remove cultured marble bathroom vanity countertop goshenplumber Building & Construction 4 03-04-2011 04:56 PM
bathroom remodel at a stand still becuase of floating vanity installation diy'er on LI Kitchen & Bath Remodeling 10 11-23-2009 01:12 PM
Machining Marble SideSplash for Vanity jombres Remodeling 4 12-03-2006 05:38 PM
