End Caps On Copper Tubing - Plumbing - DIY Home Improvement | DIYChatroom
Old 02-08-2009, 09:39 PM   #1
end caps on copper tubing
I am remodeling my bathroom. A plumber capped off the copper feed lines. I am trying to finish the job myself. How do I remove the caps?
nolankyle is offline   Reply With Quote
Old 02-08-2009, 09:47 PM   #2
Rewards Points: 162
The easiest way to deal with this is leave the caps in place and cut the tubing just behind the cap with a tubing cutter. Solder your new valve in place and you are set.
You could remove the cap, but it's not worth the time or effort.
Some advice you receive on the internet can be worth exactly what you paid for it - be careful.
stubborn1 is offline   Reply With Quote
Old 02-08-2009, 09:49 PM   #3
Registered User
Termite's Avatar
Normally you'd cut them off with a tubing cutter. Then clean the pipe with emery cloth and solder on the valves or use compression valves.
You'll definately need to turn off the water supply before doing this.
Old 02-09-2009, 01:01 PM   #4
Rewards Points: 5,336
If this is a bump in your remodeling road, you had better be sure what you're doing once you cut the caps off. As stated before, you need to turn off the water to the whole house to do this. If you don't do it correctly, you can't turn the water back on.
Ron
Old 02-09-2009, 04:27 PM   #5
bradnailer's Avatar
If you have room, cut off the caps with a tubing cutter then rather than soldering on a new valve, solder on a threaded adapter, then screw the valve on to the threaded adapter.
bradnailer is offline   Reply With Quote
Old 02-12-2009, 06:11 AM   #6
I agree with you man, but i think there's a one way to removed the cap of tube... But i am not for that way to removed the cap..maybe try to find an answer in copper sink manufacturer what is the easy way to remove the caps on copper tube!!!
Copper Sinks
shadow0000 is offline   Reply With Quote
Old 02-12-2009, 06:52 AM   #7
Since you don't know the basics of plumbing why would you attempt to remodel your bathroom?
bwalley is offline   Reply With Quote
Old 02-12-2009, 07:16 AM   #8
You should not only turn off the water but try to drain any presure in your line by opening the lowest tap in the house after the main lines are shut off.
IF you really need to reuse the joints, reheat them and GENTLY grip the caps after they are heated with a set of vise grips and give them a turn. You will know they are heated when the solder at the joint liquifies.
It is often better to start with a fresh cut clean joint.
Chemist1961 is offline   Reply With Quote
Old 02-12-2009, 07:48 AM   #9
BUILDER / REMODELING CONT
buletbob's Avatar
if your going to use the soldered type of shut offs make sure you break them down, you don't want to expose the washer assembly to the extreme heat. once cooled reinstall them . BOB
Old 02-12-2009, 09:25 AM   #10
Registered User
Termite's Avatar
This is a DIY site, and a lot of our visitors and members don't know the basics of plumbing or other trades. Yes, there's a lot to learn but lots of people learn it by doing it. No reason to make discouraging statements or questions.
Old 02-12-2009, 10:22 AM   #11
bradnailer's Avatar
That's one of the reasons I suggested sweating on a threaded adapter rather than sweating on a valve directly.
If you don't have room to cut the cap, then after you shut off the water and before you try to heat and remove the cap, drill a hole in the lower face of the cap to relieve the pressure and drain any water that might be in the line. A line free of water is much easier to sweat.
Old 02-12-2009, 11:18 AM   #12
buletbob's Avatar
I didn't see that mentioned in your post. Thats why I brought it to the posters attention, My preference is if your going to sweat a fitting ! you might as well sweat the shut off on and not worry about possible leaks.
Old 02-12-2009, 12:17 PM   #13
bradnailer's Avatar
Out where I live, the water is sort of nasty and shut off valves only last a few years. With the threaded adapter, it's a lot easier to swap out the valves. Other reason for my suggestion of using a threaded adapter.
Either way is OK though.
Old 02-12-2009, 01:23 PM   #14
Custom Cabinet Maker
quarter turn ball valves last a very very long time :}:}. Both compression and sweat are made
skymaster is offline   Reply With Quote
Old 02-12-2009, 04:28 PM   #15
bradnailer's Avatar
I just installed a couple of those about a month ago. We'll see how they last. I have trouble with the old valves leaking around the stem due to corrosion.
Copper tubing for icemaker? BigJimmy Plumbing 15 09-11-2011 03:23 PM
copper strap around copper pipe? analogmusicman Plumbing 3 06-04-2008 11:55 AM
PVC, copper, tubing? rodsteryz Plumbing 3 05-14-2008 05:22 PM
removing copper caps equineman Plumbing 4 04-07-2008 11:05 PM
Questions about copper tubing... SDeeter19464 Plumbing 3 04-21-2006 09:11 AM
