Empty Bowl! - Plumbing - DIY Home Improvement | DIYChatroom
Old 02-25-2009, 06:11 PM   #1
Empty Bowl!
Just finished installing toilet in basement bathroom that was plumbed by builder. Everything seemed to go well except for the amount of water in toilet bowl. After a flush it is fine but after a few minutes all the water seems to drain leaving about 1/4 cup of water. I adjusted the water level from inside the tank which puts more water in the bowl after a flush but with the same result after about 5 minutes. How can I fix this?
will_53115 is offline   Reply With Quote
Old 02-25-2009, 06:19 PM   #2
the Musigician
DangerMouse's Avatar
could it be cracked and leaking??? can you see/check below?
DM
Old 02-25-2009, 06:41 PM   #3
No leakage at all. I must have flushed 25 times.
Old 02-25-2009, 06:46 PM   #4
the Musigician
maybe your vent is clogged and it's sucking the water out of the tubes? this is a weird one.... guys?
DM
Old 02-25-2009, 07:38 PM   #5
Does the sewer go into an ejector pump or directly into the sewer?
tommulligan is offline   Reply With Quote
Old 02-25-2009, 07:49 PM   #6
Directly into the sewer.
Old 02-25-2009, 08:22 PM   #7
Possible it is a crack in the trap that is leaking right into the drain pipe. No evidence left behind. Fill the bowl with a bucket and have someone else flush a toilet elsewhere in the house. Watch to see if the basement bowl empties or starts moving the water in it. That would be a vent problem.
If you have never made a mistake, you haven't done much.
majakdragon is offline   Reply With Quote
Old 02-25-2009, 08:23 PM   #8
Believe it or not you probably have a clog. Even if the bowl flushes completely it may be slower than normal what happens is as the water squeezes past the blockage it creates a siphon effect pulling water from the bowl.
Try a plunger see what happens.
Old 02-25-2009, 08:40 PM   #9
plumbing contractor
PLUMBINGITALL's Avatar
I think you have a vent problem. Check the vent for that toilet and make sure it vented properly. Sounds like you are finishing a basement that was rough plumbed and now you are finishing it. Make sure the vent is not caped off or something.
PLUMBINGITALL is offline   Reply With Quote
Old 02-25-2009, 09:47 PM   #10
Ok, I will try all the tests that you guys threw out and let you know when I get home. If it matters I cut the cap off, put the flange down and put on the toilet so nothing "fell" down the drain. Shows how much I know, I thought it was because the drain was dry! Be back soon....
DIY Tips and Tricks! DangerMouse General DIY Discussions 171 09-04-2015 10:50 AM
Toilet Bowl Water encouraged Plumbing 2 12-29-2008 10:11 AM
Toilet bowl only 1/3 full eyeblazy Plumbing 9 11-06-2008 06:16 PM
Toilet Bowl to Horizontal Waste pipe BOBC Plumbing 3 08-30-2008 02:17 PM
Toilet bowl shims rjniles Plumbing 2 08-23-2007 06:06 PM
