Emergency Repair Advice! - Plumbing - DIY Home Improvement | DIYChatroom
Old 03-23-2011, 02:00 PM   #1
Emergency repair advice!
So we have just moved into a new house.
The grass hasn't been cut in months so that's what I was doing today when I happened to come across some sort of drainage/sewer cap and of course the lawn mower chewed it up.
The area around this cap was boggy previously but I had no idea until today and I found the cap.
Now there is no damage to the actual pipe that runs through this cap but the water coming thru shower+faucet is slightly brown.
Uploaded with ImageShack.us
Any ideas what I can do?
wilto is offline   Reply With Quote
Old 03-23-2011, 02:02 PM   #2
Master General ReEngineer
Bondo's Avatar
Rewards Points: 1,706
Ayuh,... No idea what it's for, but grab a rubber fernco cap, 'n cap it...
Old 03-23-2011, 02:07 PM   #3
Just fit one of these on top?
http://www.homedepot.com/h_d1/N-5yc1...atalogId=10053
Old 03-23-2011, 02:09 PM   #4
Bondo's Avatar
Originally Posted by wilto View Post
Ayuh,... That's the ticket...
Put a pin or stick in the ground next to it, so's ya don't hit it again...
Old 03-23-2011, 02:10 PM   #5
Thank you!!!
Old 03-23-2011, 02:19 PM   #6
Diamater is 6inch - the biggest fernco have at home depot is 4...yikes
Old 03-23-2011, 07:20 PM   #7
Plumber
TheEplumber's Avatar
Rewards Points: 904
Could be a valve riser for water service or irrigation. Pump out the water and see whats down there
Old 03-23-2011, 09:22 PM   #8
Homerepairguy's Avatar
Rewards Points: 998
...snip... but the water coming thru shower+faucet is slightly brown.
The brown water from your shower and faucet is unrelated to that pipe with the broken cap. The brown water from the shower and faucet is probably coming from your water heater and that you need to drain and flush it.
If you do that, after the drain and flush procedure, suggest flushing out your hot water lines by opening your laundry tray faucet first and run hot water until the water runs clear. Then remove all of the aerators in the kitchen and bathroom spouts and run hot water through them until they run clear. Doing this will give you a good chance of getting any sediment out of your hot water lines without clogging stuff.
HRG
Homerepairguy is offline   Reply With Quote
Old 03-24-2011, 07:58 AM   #9
Rewards Points: 1,548
If possible, start by not using hot water for several hours. Turn off the water heater. (Knob turned to "pilot" for gas heaters)
Then tun off the main water valve, open any faucet upstairs, then drain several gallons (not the entire tankful) by opening the water heater bottom drain valve. (Stop when the water runs clear.) Close the faucet, open the main water valve, and drain more from the water heater drain. Again, stop when the water runs clear.
Finally open a hot faucet, wait for water to gush out, then turn the water heater back on.
Old 03-24-2011, 10:34 AM   #10
Bondo's Avatar
Ayuh,... Try an industrial plumbing supply house, rather than HD...
Repair Compounds saggdevil Painting 3 04-25-2010 03:02 PM
Advice on deck repair gabchoud Carpentry 8 09-12-2009 01:13 PM
drywall repair next to an outlet - advice needed... myke232 Drywall & Plaster 2 08-19-2009 12:25 PM
advice needed on roof repair gdread Roofing/Siding 4 08-13-2009 01:08 PM
Electrical Advice Caution!!! Mike Swearingen Electrical 12 03-05-2008 11:51 AM
