| DIY Forum | DIY Blogs | Photos | Woodworking | Extreme How To | Advertise | Contact Us |
Previous Thread
Next Thread
More On This Topic
Prep Work for Replacing a Toilet
by Expert Village
Today we are replacing a disabled toilet. It leaks and it also leaks down at the base where it’s cracked at, so we’re just going to replace the whole entire thing. If you buy a toilet that is- it’s called a toilet in a box. It has... Read More »
How to Replace a Toilet Flapper
by Expert Village
If your flapper needs to be replaced, it’s probably the simplest thing you can do. All you’re going to do is flush the toilet, let it run out- turn off the supply line first. Once you’ve drained the tank, you’re going to simply... Read More »
How to Adjust Toilet Tank Handles
by eHow.com
At one time or another we all have heard the dreaded sound of running water coming from the toilet. That doesn't mean you need to call for professional help. Before recruiting a plumber, makes these simple adjustments to your toilet tank's handle and... Read More »
Repairing Flush Handle in a Toilet
by Expert Village
Something else that can go wrong with the toilet is the flush handle. Either the plastic guard rim or the metal arm can break; the handle can fall off, and separate where they're pressed together. The most important thing you have to know about changing... Read More »
How to Force the Trap of a Toilet
by eHow.com
Forcing the trap of the toilet is a great way to empty the toilet completely before you remove it. Forcing the trap is also a good way to unblock the drain. If something gets dropped in the toilet, too much toilet paper gets stuck or something else... Read More »
