Eljer toilet parts
I have a very similar model Eljer, but with a round bowl. Except for the original poster's elongated bowl, it appears to be the identical model, circa 1972 or so. BTW... the flush valve assembly can be found at any home improvement or hardware store, as it's Eljer specific. I've never had any problem finding the Eljer "ball" flush valve. Try your local True Value Hardware if you can't find it at either Home Depot or Lowes.
I'd like to replace this toilet, but it's located in a very small bathroom, and I can't find any toilet that meets similar mechanical specifications. The Eljer is only 26.5" inches deep, and nothing on the market appears available with that depth dimension. Plus, the rough in is 14" - another strike against finding an appropriate replacement. Any overall depth greater than 27" inches would be a problem as it's directly across from the shower entrance.
