Old 08-02-2011, 10:27 AM   #1
Eljer toilet circa 1996 question
This house has Eljer one-piece toilets from 1996. I just replaced the fill valve and flapper on one of them and I have an issue now where the flapper doesn't shut down to the hole opening sporadically. It's as if the Korky flapper isn't heavy enough to flop back down while the water is gushing out of the holes in the circular area where the flapper and fill pipe is contained. This only happens occasionally, when you don't flush it 'just right', or if you flush it twice, only when all the water evacuates out of that cylinder. Basically on the inside of the toilet there is a round plastic cylinder in the middle of it and inside the cylinder is the flapper/drain hole and the fill valve tube where the water from the fill valve sprays into. At the base of the cylinder on the inside there are holes that the water flows out of from the fill tube.
Is a special 'Eljer' flapper needed here? Perhaps a heavier 'Eljer' flapper?
Anyone have experience with Eljer one-piece thrones?
noone is offline   Reply With Quote
Carrier Cobra circa 1996 w/ electronic ignition ChuckT HVAC 4 11-03-2011 07:36 PM
Help me check my logic on clogged drain and overflowing toilet Southlake_Ed Plumbing 10 01-05-2010 08:52 PM
Toilet jpark Plumbing 18 01-05-2009 08:12 AM
Toilet install question rolls831 Plumbing 9 07-09-2008 09:00 PM
New Toilet Install Question uokman Plumbing 4 04-23-2008 04:34 PM
