Eljer Steel Tub Floor Support - Plumbing - DIY Home Improvement | DIYChatroom
Old 12-01-2011, 10:30 AM   #1
Rewards Points: 562
Eljer steel tub floor support
I am putting a Westlake model Eljer tub in. Just did exact same tub in a different bath. When you step inside the tub like to take a shower it feels like it is flexing and not solid even tho it is a steel tub,,,,directions say no further support needed.
Maybe cause the house (old) was a little crooked and we used what we had. Tub drains okay BUT just not as solid as I would like. Can I set THIS new tub in a mortar bed of thinset??? or other mortar?you tell me if there is any way to absolute support tub floor to make it "SOLID as a rock???
Related issue I measured floor to bottom of lip where 2 X4 gets mounted on wall for support and drain end of tub is 1/4 inch more than foot end of tub...seems like it should be other way around and tub bottom should set directly on solid subfloor!!
TIA--don
4just1don is offline   Reply With Quote
Old 12-01-2011, 12:14 PM   #2
Lately I need to "re-engineer" various products to make them work properly.
My tub is solid because I added shims under it to give it additional support (which was not mentioned to do in the instructions).
I also added piers and a beam under it in the crawlspace.
I would say do whatever you need to do to make it right!
Billy_Bob is offline   Reply With Quote
Old 12-01-2011, 12:50 PM   #3
Tileguy
Bud Cline's Avatar
Rewards Points: 558
Yes, use bagged Mortar Mix. DO NOT use thinset.
XXX
drilling through steel I beam DIYguy2000 Building & Construction 3 11-21-2011 08:39 AM
Wood or Steel wall studs? dredogol Building & Construction 2 07-10-2011 07:31 AM
Steel Posts for Screen Porch dobbsj Building & Construction 2 07-15-2009 05:47 PM
Floor bounce joist sistering joehomeowner Building & Construction 24 05-10-2009 01:50 PM
"Maintenance Free" Siding Materials (Vinyl, Steel, Fiber Cement) diggitydog Building & Construction 12 01-23-2009 04:24 PM
