Eliminating One Bathroom Sink - Plumbing - DIY Home Improvement | DIYChatroom
Old 02-02-2012, 01:37 PM   #1
Rewards Points: 87
I'm remodeling a bathroom and eliminating one of two vanity sinks in the process.
The left side sink is the one being eliminated. There is a roughly 7' drain run (iron) through the wall where it connects to the right side sink drain, which is right above/near the main soil pipe.
What is the best method to abandon the drain line inside the wall? Can I just cap it at the current location (along with the supply lines) and drywall over? That would be a good option in case anyone wanted to install a second sink again in the future.
Does that leave too much potential for a leak, backup, damage, .... I have full access to the plumbing from the basement, so I can also cap the supply lines down there.
Thanks.
tev9999 is offline   Reply With Quote
Old 02-02-2012, 06:56 PM   #2
Plumber
TheEplumber's Avatar
Rewards Points: 792
Cap the waste in the wall and the water as close to the mains as possible
Old 02-02-2012, 07:01 PM   #3
DIY staff
Rewards Points: 7,174
DRAIN--Unscrew the nipple that is sticking out of the wall ---screw in a plug (doped and taped)
Water lines---those are old pipes--safest to remove and cap in the crawlspace--
Old 02-03-2012, 09:00 AM   #4
Rewards Points: 87
Simple enough. Thanks!
Replace bathroom sink drain? Dave321 Plumbing 2 06-07-2011 12:37 PM
Kitchen sink backing up to downstairs bathroom! macon215 Plumbing 1 09-25-2010 06:41 PM
Installing bathroom sink - drains off slightly less than pipe diameter lazzlazz Plumbing 17 05-21-2010 05:12 PM
Caulking around bathroom sink KarenRB53 Plumbing 2 09-17-2009 10:21 AM
