Old 04-18-2011, 10:45 AM   #16
elevate electric water heater?
actually the new water heater is the same size in gallons but the overall height is like 4" taller. which is what also prompted this issue about setting the water heater on bricks. if i didnt need to, then i wouldnt have to redo alot of the 90 degree elbows that you see in the pictures. i would just have to cut the straight run and re-solder.
if it has to be on bricks, then it will be cutting it to close for comfort to the existing elbows/couplings.
crankbait09 is offline   Reply With Quote
Old 04-18-2011, 10:55 AM   #17
Owner
LateralConcepts's Avatar
It doesn't have to be on bricks. Just take your measurement. I'm guessing your bricks aren't quite 4", so you may need to just shim it up a little with a piece or two of plywood.
Brad Penske, Operations Manager - Coeur d'Alene, ID
Lateral
CONCEPTS,LLC - Sewer & Septic Line - Video Inspection, Locating, Consulting
(208) 818-8241
LateralConcepts is offline   Reply With Quote
Old 04-18-2011, 11:26 AM   #18
ANYWAYS, the existing water heater is inside our house and is in one of our closets. so no where near outside temps. the water heater was installed on top of bricks which leaves it about 2-1/2" off of the floor.
from first thread...
Old 04-18-2011, 12:35 PM   #19
Owner
Ahh gotcha. Actually after re-reading my last post, I think I was thinking backwards anyway.
Basically if you remove the bricks for the new install, you'll still then be 1 1/2" taller right? So you will need to cut out and re-solder. Or as Eplumber mentioned, use stainless flex lines with sharkbite fittings.
Now that I look at your pics again, I'd also suggest getting rid of that saddle valve (needle valve). When you cut out a section of the vertical. Install a copper tee and straight stop to accommodate that 3/8 or 1/4" copper line.
Lateral
(208) 818-8241
Pressure drop across water heater, low hot water flow HVAC_NW Plumbing 2 01-17-2011 11:43 PM
Solar hot water indatom123 Green Home Improvement 0 12-19-2010 01:01 AM
electric water heater rewire dghowery Electrical 6 10-13-2010 06:06 PM
Water heater drain mechanism (10 year old) guptaalok Plumbing 1 01-02-2009 06:40 AM
Periodic release from (I think) the T&P valve on the water heater alexz Plumbing 3 08-15-2006 11:31 AM
