Old 03-24-2008, 06:42 PM   #1
Question
electrolysis on copper pipe
i recently realized that using galvanized metal tape to suspend copper pipe from joists was bad in that it caused electrolysis. i have corrected the mistake with copper tape since, however, was wondering how bad the damage is and whether it would continue to worsen ? the turquoise corrosions stuff is somewhat visible but not too bad.
Old 03-24-2008, 07:11 PM   #2
Send a message via AIM to Marlin
It probably isn't going to hurt anything or get worse. If you want to be completely sure, take some sand cloth, steel wool, or fine grit sandpaper and polish the area to a shine removing all the corrosion then wipe it off with a clean rag.
Marlin is offline   Reply With Quote
Old 03-24-2008, 07:52 PM   #3
Res Ipsa Loquitur
If all the work is complete you can just pad between the strap and the pipe with some plastic or electrical tape, pieces of foam pipe wrap or other seperator. It would probably become a major issue if you live in a very humid environment.
Did you ever stop to think, then forget to start again?
handyman78 is offline   Reply With Quote
Old 03-24-2008, 07:56 PM   #4
Building and plumbing
USP45's Avatar
Or use some scrap garden hose sections. Thats what we done when we installed a drop ceiling and the suspension wires (Steel) came into contact with the copper pipe. we cut sections of old hose and placed under the wires that touched the copper tubing.
Sometimes them bristly pot and pan scrubbers that the Mrs uses on dishes works good to clean pipe too!
USP45 is offline   Reply With Quote
Old 03-24-2008, 08:41 PM   #5
If you read his post he's already replaced the galvanized with copper so separating the two metals is no-longer and issue. The question at hand is will the existing corrosion cause any damage.
The answer is not likely if it is only light corrosion, but if you're feeling ambitious it won't hurt to remove it.
Old 03-24-2008, 09:08 PM   #6
Wink
thank you gents !
can you bury copper pipe ? amakarevic Plumbing 12 08-05-2009 07:25 PM
How to protect 3/4" copper pipe passing through concrete Mike Warner HVAC 2 03-13-2008 01:37 AM
Old preasure valve, new copper pipe. fast380 Plumbing 5 01-12-2008 11:36 PM
Can I Extend the 3/4" Copper Pipe? froddan Plumbing 2 07-23-2007 05:03 PM
Type L Or M Copper Pipe bobo Plumbing 1 11-20-2005 08:53 PM
