Old 10-30-2009, 09:23 PM   #1
Question
Electrical solder on copper pipes?
I just soldered a pex fitting (I guess it's brass) onto a baseboard radiator (copper pipe). Is this a bad thing? Should I redo it? I know the other way around is bad due to the acid in the flux, but i've never heard if this is bad. What do should I do?
mosh is offline   Reply With Quote
Old 10-30-2009, 10:36 PM   #2
Originally Posted by mosh View Post
Should I redo it?
Yes. It is cheap to do it the right way, with the correct plumbing solder
Anti-wingnut is offline   Reply With Quote
More On This Topic
Hi, this is Jeff Naylor from Mtroniks in Mesa, Arizona for Expert Village. One practical use for your new soldering skills is cable repair. This is an instrument cable. It has a shielded outer wire and then an insulated inner wire. The inner wire is your... Read More »
Hi, this is Jeff Naylor from Mtroniks in Mesa, Arizona for Expert Village. Your prep work is really dependent on what type of connector you're going to be putting on your speaker cable. Now, as you saw on our last section, we tin the wires if we're going... Read More »
Hi, this is Jeff Naylor from Mtroniks in Mesa, Arizona for Expert Village. As a musician, I'm always going through cables and its really nice to be able to fix your own cables. In this next section, we're going to learn how to fix an instrument cable... Read More »
Hi, this is Jeff Naylor from Mtroniks in Mesa, Arizona for Expert Village. In this section, we're going to be demonstrating proper heating techniques and to illustrate my points; I'm going to be soldering this resistor on to this circuit board. Proper... Read More »
Soldering Tips
Soldering Tips by Expert Village
Hi, this is Jeff Naylor from Mtroniks in Mesa, Arizona for Expert Village. Thank you for joining me for today's video. I hope you enjoyed it. Remember, safety first. Always wear safety goggles. Always be aware of your surroundings. We used a lot of tools... Read More »
How To Solder Copper Pipes thekctermite How To Guides 67 12-11-2009 10:55 AM
Replacing galvanized with copper pipes. Twinvtec Plumbing 18 02-24-2009 09:53 PM
Burying exposed copper pipes ryan_s HVAC 1 11-20-2008 08:20 PM
When soldering copper, what causes the solder not to "suck in"? Piedmont Plumbing 10 10-25-2008 09:59 AM
Copyright ©2000 - 2010, Jelsoft Enterprises Ltd.
