electrical main panel and copper pipe
i was wondering if there is any code regulations related to the vicinity of an electrical main panel and copper water supply pipe ? i ran my pipe to go just a few inches away from the panel.
None that I am aware of. The box should protect the inside from any water entering. I always avoid the situation, if possible, but have also been within a few inches in some cases.
No plumbing, gas, or HVAC can be located immediately above the panel, because that is dedicated space. You can't have pipes protruding in a 30" wide by 36" deep space in front of the panel, because that is the reqiured clear working space for the panel. Other than that, there is no proximity requirement for plumbing to electrical.
i'll try to take a picture tonight and post it. thanks !
Good idea. I'll let you know if what you have is code-compliant or not. :thumbsup:
2 Attachment(s)
here we go, boss. the fat pipe is for radiators (1.5"), the skinny one is h20 supply (3/4).
The fat pipe is a problem because it encroaches into the clear space required floor to ceiling in front of the panel. By code, it cannot be there, and as an inspector I'd turn it down if it is newly installed. The clear space is 30" wide, 36" deep in front of the panel, measured from the front of the panel. Imagine a 30"x36" phone booth as tall as the ceiling with its 30" face resting against the face of the panel...That space can't have anything else in it, including that stud wall.
If the other pipes are directly under the panel, they're not encroaching into the required clear space and are not a problem. Looks like they're hugging the wall aren't they? There's some spooky-looking wiring around that panel. ;-) |
Whats your plan with that wall your building? It looks like you have a lot of slack in most of the cables. I am thinking you might be able to build the wall closer to the brick and install the panel in the new finished wall. But you still have to maintain the clearance in front of the panel, so depending on what you plan to use the finished space for it may or may not work. Jamie |
Fat pipe can go behind the panel but in front or above the panel.
I'd consider getting an electrician over there any allowing them to deal with the permit issues. If your in a larger city the electrical inspector may be different than the building / plumbing inspector. Jamie |
You mean all this time we've been helping you you've been working without permits? Shame!!! Bad bad bad!!! :laughing::no:
Honestly, the inspector probably has no idea what the inside of your house looks like, or what it looked like before you made updates. If you haven't lived there for the last 10 or 15 years, you can always say that the previous owner did the work. Most cities are interested in the current permitted scope of work, and unless something just screams "done without a permit" they won't take interest (there are exceptions to that of course in some cities). |
The Fat pipe, little pipe and the wall need to go, or the panel relocated. |
| All times are GMT -4. The time now is 12:47 PM. |
