Electric Water Heater TPR Valve Leaking - Plumbing - DIY Home Improvement | DIYChatroom
Old 03-16-2013, 12:51 PM   #1
Electric water heater TPR valve leaking
I noticed my TPR valve was leaking on my 8 year old water heater. I replaced it, no change. I lowered the water pressure, no change. I lowered the water temperature, no change.
What next?
shmelvin is offline   Reply With Quote
Old 03-16-2013, 01:40 PM   #2
Civil Engineer
Rewards Points: 4,572
Since you replaced the TPR and it still leaks, there is a pretty good chance the TPR is doing its job, specifically sensing an overpressure or over temperature condition. Likely the problem is over pressure, since you apparently turned down the temperature with no effect.
The pressure in your system can go over normal if you have a waterlogged expansion tank. If you are on private water (pump), you almost certainly have such a tank, and if the bladder fails internally, you can be left with a situation where there is no expansion room for water when it gets hot, which would lead to your symptoms. If you are on city water, there may not be an expansion tank. Perhaps you can tell us how your water supply is set up.
Daniel Holzman is online now   Reply With Quote
Old 03-16-2013, 02:09 PM   #3
Rewards Points: 1,772
Install a hot water tank expansion tank on the cold water inlet to the tank.
Old 03-16-2013, 02:10 PM   #4
Doing it myself
Alan's Avatar
Rewards Points: 2,086
describe the frequency of the leak, and the amount of water coming out?
Agree with above : You replaced it, no change, that means the valve is doing it's job, either over pressure (most likely) or over temperature.
Either the regulator has failed and your pressure is just high (you say you adjusted it, did it stay where it was at when you changed the pressure? Are you sure you lowered the pressure, not raised?) or it is slowly creeping up over a short period of time.
OR
The water in the heater is expanding, and has nowhere to go. You alleviate this by installing an expansion tank.
Journeyman Plumber
Old 03-16-2013, 06:37 PM   #5
City water
I have city water no expansion tank.
just replaced the elements they were a bit crusty but I've seen worse, there was some calcified gravel in the bottom of the tank but way below the element.
If that doesnt fix it I think its time for a new heater?
Old 03-16-2013, 07:18 PM   #6
Plumber
TheEplumber's Avatar
Rewards Points: 452
You haven't said what your pressure is. How do you know you lowered it? Is the pressure staying consistent?
You must have a PRV- if so you need an expansion tank as mentioned earlier.
Old 03-16-2013, 07:54 PM   #7
As hot water expands in your hot water tank it needs somewhere to go. If you have a pressure reducing valve or check valve on your incoming water you may need an expansion tank because the PR valve bypass may have blocked over time.
Old 03-16-2013, 08:45 PM   #8
no change
Well it's still leaking not steady i think as heating up and expanding
Old 03-16-2013, 08:50 PM   #9
Rewards Points: 228
reread posts 6&7.
jmon is offline   Reply With Quote
Old 03-16-2013, 08:50 PM   #10
Plumber
Rewards Points: 452
T&P valves are a safety device. If it's leaking- even a little, you need to be concerned. Run the proper checks on your water pressure. Replace the PRV if needed and install a expansion tank
Old 03-17-2013, 08:29 AM   #11
I turned down the water pressure at the regulator and saw a noticable drop in pressure at the shower and faucets.
I have had no problems with the system up until last week.
The tank was installed 8 years ago (with a 6 year warantee)
Old 03-17-2013, 08:35 AM   #12
Rewards Points: 1,216
How many problems have you had with it for 8 years? If it operated for 8 years OK you shouldn't need a expansion tank now unless something was changed.
No Warranty Means- If it breaks in half you get to keep both halves.
COLDIRON is offline   Reply With Quote
Old 03-17-2013, 09:02 AM   #13
thatís the crazy thing...Nothing has changed it just started to leak so I changed PR valve. this morning I have no leaks but the hot water has not been used. It seems to happen when the shower is in use obviously draining adding cold water and heating up causing expansion. no one in my neighborhood has an expansion tank.
Old 03-17-2013, 09:33 AM   #14
Read post 7 or leave it leaking. Not my house.
Old 03-17-2013, 12:21 PM   #15
If you just changed the pr valve that's not good enough.
Now you have to set the pressure you want to achieve.
How to diagnose gas valve problems Nestor_Kelebay How To Guides 28 10-30-2013 05:19 PM
Brand new water heater TPR valve spraying fetzer85 Plumbing 50 03-21-2013 12:32 AM
Water Heater Pressure Relief Valve Leaking. merton Plumbing 2 03-29-2010 08:37 PM
Natural Gas Water Heater Leaking from Release Valve Pipe? psumike Plumbing 6 01-14-2009 08:18 PM
