Electric Water Heater Shut Off - Plumbing - DIY Home Improvement | DIYChatroom
Old 02-26-2012, 02:38 PM   #1
electric water heater shut off
My water heater is inside my kitchen cabinets. My sink is next to the heater and overflowed onto the floor. Would this turn off my water heater? The cabinet is installed and the water heater is closed in. Could my overflowed water have turned off the heater if the water landed on the floor near the cabinet?
caryn keeper is offline   Reply With Quote
Old 02-26-2012, 02:42 PM   #2
Rewards Points: 13,300
Did the water run down inside of the heater?
A picture of what you may help. Just open up the cabinet doors and step back so we can see the relationship.
caryn keeper (02-26-2012)
Old 02-26-2012, 02:45 PM   #3
unfortunately the tank is inside the walled in cabinet and can only be accessed by taking out the cabinet.
Old 02-27-2012, 08:28 AM   #4
retired elect/hvac/plumb
plummen's Avatar
Location: south east of omaha/The island of misfit contractors
Rewards Points: 2,020
Well all I can say is if you cant see the heater,theres no way we can see it any better than you can
Have you checked fuses/breaker?
"facts" have no relevance to this discusion
Posting from a concrete bunker under a non descript barn
plummen is offline   Reply With Quote
Old 02-27-2012, 08:43 AM   #5
Master Plumber
Javiles's Avatar
Rewards Points: 990
What may have happened is the heater over heated (bad thermostat?) popped the T&P valve open then the high limit shut the heater down. Thatís the little red button on the thermostat. If thatís the case you may have a bad or starting to go thermostat. Also find a place to relocate that water heater if possible. Good Luck.
Experience is Knowing what to do next, Skill is knowing how to do it
http://www.americandrain.net
Javiles is offline   Reply With Quote
Old 02-27-2012, 04:45 PM   #6
Rewards Points: 1,574
How can installing a water heater inside of a permanent "box/cabinet" be 1. a good solution, 2. a code-legal solution?
bob22 is offline   Reply With Quote
Old 02-27-2012, 08:57 PM   #7
Rewards Points: 582
yes agree with bob...what the @#@#$%....can't be right is this a trailer???
Old 02-28-2012, 12:22 AM   #8
Master Plumber
Javiles's Avatar
Rewards Points: 990
We have tons of them here in the Miami beach area, they started with the old table top models in the kitchen, over the years kitchens get remodeled and the water heater has no place to go so they installed them under the counters inside the cabinets crazy man, pain in the but to get to never mind replacing.
Old 02-28-2012, 07:39 PM   #9
Rewards Points: 582
wow what a pia only seen something close to it in mobile homes...
electric versus propane water heater Jeremy Hillary Boob, PhD Appliances 7 01-30-2012 06:23 PM
Water heater - Gas or Electric Sartrean Appliances 17 01-13-2012 05:45 PM
should i install electric water heater to save $$? 19mquinn79 HVAC 7 06-26-2011 03:00 PM
Electric Water Heater Issues - Water Too Hot after tstat replacement and Sulfur Smell marman4880 Plumbing 4 08-05-2010 05:25 PM
Electric Water Heater Problem mw2727 Plumbing 4 08-21-2008 02:51 PM
