Electric Water Heater Rumbling Noise - Plumbing - DIY Home Improvement | DIYChatroom
Old 08-12-2011, 01:44 AM   #1
electric water heater rumbling noise
heater makes rumbling noise anytime but definately in the morning.I have a timer on it that turns on at 4:30 P.M. and off at 8:00 P.M. the heater is about 5 yr. old and I tried draining....any ideas
big island is offline   Reply With Quote
Old 08-12-2011, 06:46 AM   #2
"tried draining"????? What you describe sounds like a lot of debris, calcium buildup in the tank. If you tried to drain but nothing came out, that is the problem. With the drain valve full open, run a coat hanger or similar up the drain to break up deposits. Careful, that is hot water, might be best to shut off the power and let it cool or run the hot water out. Once you have water flowing from the drain, let it run until it is nearly clear, Repeat in a week or so, and every 6 mo.
Old 08-12-2011, 11:51 AM   #3
by tried draining I meant that I drained the tank empty but only clean water came out.It was not plugged
Gas Water Heater, water not hot enough - Thermostat or Sediment makunag Plumbing 15 08-27-2010 11:00 PM
Trouble With Electric Hot Water Heater whitedavidp Plumbing 8 04-22-2009 05:16 PM
Trouble With Electric Hot Water Heater whitedavidp Appliances 12 04-06-2009 06:47 PM
Trouble With Electric Hot Water Heater whitedavidp Electrical 7 04-06-2009 04:26 PM
Replacing a Water Heater with Electric One 2031pratt Plumbing 3 12-26-2008 09:17 AM
