Electric Water Heater Problem- Hard Water - Plumbing - DIY Home Improvement | DIYChatroom
Old 07-25-2013, 01:00 PM   #1
Rewards Points: 135
Electric water heater problem- hard water
GE Smartwater 50 gal Mfg date 12/2006. My area has hard water. I am trying to drain the tank in order to inspect and possibly change the heating elements. The water temp does not seem hot enough. I have the cold water supply shut off with a hose connected to the valve at the bottom of the tank. No water is coming out. When I open the cold water supply valve there is a pretty good flow coming out. I left the cold supply open for a few minutes to clear any hard water sediment blockage and turned it off and still no flow. What do I do?
A side issue- I was away for a week and came back to no hot water- the ckt breaker was blown. I reset it and have hot water but the same temp problem.
elmaur is offline   Reply With Quote
Old 07-25-2013, 02:13 PM   #2
Rewards Points: 6,652
You have to open a faucet in te house, to allow you to break the vacuum, when you shut off te water supply.
Closed loop systema do not drain, unless you introduce a way for them to "Breathe", when purging, or have a liquid flow to move the product.
Old 07-25-2013, 03:19 PM   #3
Rewards Points: 13,752
Also you may end up having to stick a coat hanger up inside the drain valve to try and break it up enough to get it flowing.
Old 07-25-2013, 06:16 PM   #4
Rewards Points: 1,958
Also turn off all the electricity to the tank before you drain it.
AS for your hot water it may be bad thermostat you have 2 one upper and a lower our a bad element you have 2 of them also. You will need a multimeter to trouble shoot it.
Old 07-25-2013, 06:24 PM   #5
PoleCat's Avatar
Rewards Points: 1,646
Odds are the bottem element got buried in rock and burned up. Take the time to scrape all of the sediment out before reinstalling the new element.
"Ask me anything. If I don't know the answer I'll make something up."
PoleCat is offline   Reply With Quote
Old 07-25-2013, 06:39 PM   #6
Rewards Points: 1,312
Opening the TP valve will normally give enough air for gravity draining.
Old 07-25-2013, 08:14 PM   #7
Rewards Points: 135
Opening the TP valve allowed the water to drain. The upper element was fine. The bottom element had a 1/2" section burnt out- looks like a mini burst of the metal. There was moderate sediment build up on the element and at the bottom of the tank. It was very loose so I vacuumed it out with a 3/4" plastic hose taped to a shop vac hose. Hot water seems ok but I'll have to see how it holds over the next few days.
Edit: Forgot to say I did replace the bottom element.
Old 07-26-2013, 05:21 PM   #8
Good job...
Water Heater blowing out Power to Entire House tbigley Electrical 5 03-02-2011 02:54 PM
Trouble With Electric Hot Water Heater whitedavidp Plumbing 8 04-22-2009 05:16 PM
Leaking Rheem 60 gal Electric Hot Water Heater aklkuno1 Plumbing 3 10-22-2008 10:13 PM
