Electric Water Heater Problem - Plumbing - DIY Home Improvement | DIYChatroom
Old 01-29-2012, 09:43 PM   #1
Rewards Points: 135
Electric water heater problem
My electric water heater started to make a noticeably louder hissing noise periodically. It used to be a low level hissing noise. I am assuming this hissing is when the thermostat is turning on the heating elements to heat the water. About 6 months ago I removed the heater and reinstalled it in the same spot when I was renovating the area for a laundry room. I mistakenly connected power to the heater before it was filled with water and the upper heating element burnt. I replaced it and everything was seemingly ok till now. It is a GE and has a manufacture date of 2/2006. Is there a problem?
elmaur is offline   Reply With Quote
Old 01-30-2012, 08:46 AM   #2
Rewards Points: 1,512
Sediment may have formed around the heating elements. Water within the sediment may sizzle and boil rather than commingle rapidly with the rest of the water. Few experts recommend draining the tank and taking out the elements every several years to scrape off the sediment and usually the sediment does not cause any harm except if it gets too thick the element can overheat inside and burn out. Sometimes the sediment will crack and fall off by itself as the elements turn on and off, expanding and contracting slightly. Sediment on the elements may also slow down the heating of a tankful of water.
Pressure drop across water heater, low hot water flow HVAC_NW Plumbing 2 01-17-2011 10:43 PM
Electric Water Heater Issues - Water Too Hot after tstat replacement and Sulfur Smell marman4880 Plumbing 4 08-05-2010 04:25 PM
Trouble With Electric Hot Water Heater whitedavidp Plumbing 8 04-22-2009 05:16 PM
Electric Water Heater Problem mw2727 Plumbing 4 08-21-2008 01:51 PM
(Water Heater MYSTERY) Hot water out from dead tank with cold water in it? Inayity Plumbing 6 07-14-2008 08:36 PM
