Electric Shower Problem - Plumbing - DIY Home Improvement | DIYChatroom
Old 08-04-2009, 04:07 AM   #1
Electric shower problem
Hi
I have an electric shower which is playing up.
Whenever I turn it on water comes out of the pressure release hose and also leaks out of the main casing. The only way to stop it is to remove the shower head. This led me to believe that the shower head was scaled up so I descaled it but the problem persists. Related to this is that when the shower head is removed the water that comes out of the hose contains small flakey particles.
What I think is happening is that these particles build up inside the shower head causing the backward pressure, BUT, what is causing the particles in the first place?
The shower is at least 8 years old, more likely 10 years.
Matt
Matt_the_hat is offline   Reply With Quote
Old 08-04-2009, 05:52 AM   #2
I suspect the flakey particles are from your water heater. This usued to happen 10+ yrs ago but we all thought they had fixed the problem, now it seems to be back. In the water heater, under the cold water inlet is a plastic tube that directs the cold water to the bottom of the tank, the heated water comes off the top. The tube is disintegrating, which is where the particles come from. Also, it will seem the hot water is running out quickly, because the cold is now diluting the hot water at the top of the tank. Replacing the tube is fairly easy, but getting all that stuff out is harder. If the heater is older than 8-10, it might be better to replace it.
You will have to clean out all the faucet aerators, since they will become clogged also.
Old 08-04-2009, 06:04 AM   #3
Thanks for replying but my shower is electric with a cold water feed into it.
Old 08-04-2009, 10:09 PM   #4
JDC
Plumbing Contractor
JDC's Avatar
Rewards Points: 262
An electric shower....interesting. I've never seen one, but I'd guess the electric part is a small instantaneous water heater dedicated to the shower alone. Interesting indeed.
The small flakey particles could be calcium buildup in the piping of the unit. Since you mentioned a hose I assume you have a handheld spray wand. Did you only clean the rubber nozzles and the faceplate of the shower wand (head) or did you also disassemble and clean the spray plate assembly and the nozzle ring. If not, there could still be a buildup internally. I'd run the water awhile through the hose without the showerhead installed to remove as much of the foreign material as possible and clean everything again. If none of that works I'd start looking at the shower control unit itself.
JDC is offline   Reply With Quote
Old 08-04-2009, 10:22 PM   #5
Master Plumber Lon
Send a message via Yahoo to lonsplumbing
heater
Do you have well water or city water.
lonsplumbing is offline   Reply With Quote
Old 08-05-2009, 03:55 AM   #6
Blimey - I guess plumbing in USA & UK is quite different if you guys haven't heard of an electric shower. Check here: http://www.tritonshowers.co.uk/electric-showers.aspx
And what is 'city water & well water' ?
Anyway, I reckon the problem is limescale build up in the element which is getting into the water as it passes theough so going to order a new shower.
Cheers!
Old 08-05-2009, 06:27 PM   #7
Master Plumber Lon
diff water sources
Well water comes from ground water. City water comes from a city source.
Old 08-05-2009, 06:59 PM   #8
The electric showers are quite common in some areas of the world
I think you stated the problem correctly
Not sure if that can be dissasembled & cleaned
If you are buying a new one anyways I think I'd be inclined to take the old one apart after to determine the problem & possible cleaning
One idea might be to disconnect it & run some vinegar thru it (no power)
Old 08-07-2009, 12:24 AM   #9
JDC
Plumbing Contractor
JDC's Avatar
Rewards Points: 262
yep the USA and the UK must have quite different plumbing systems. Here in the states, if you told someone to go jump in an electric shower they'd tell you to go get @#%$ed! We try to keep our electric and our water separate for safety reasons. lol
Good luck!
Old 08-07-2009, 05:52 AM   #10
my electric shower keeps dripping.what could be wrong?
rana is offline   Reply With Quote
Shower valve problem stephanieb_1001 Plumbing 1 06-24-2009 04:37 PM
Preference for installing tub spout? dolvio Plumbing 7 02-11-2009 10:53 PM
Honey, I'm going to re-caulk the shower... homebound Remodeling 1 02-10-2009 09:11 AM
Shower Pan Liner Problem Hottrod33 Plumbing 9 02-02-2009 01:02 PM
shower hot water problem ajoantmug Plumbing 5 01-21-2008 04:39 AM
