Electric Hot Water Heater Luke Warm Water Problem - Plumbing - DIY Home Improvement | DIYChatroom
Old 03-19-2013, 08:55 AM   #1
I replaced the heating elements in my hot water heater a few months ago due to this same problem. Upon removing them i noticed the inside has some calcium buildup and the elements had been corroded. I flushed the tank as well as I could using the cold water flowing through the tank and did this until I saw no more sediment coming out. Fast forward 3 months and I have luke warm water again. I have increased the temp on my thermostat but this only temporarily resolves the issue. Where do I go from here?
Joker5527 is offline   Reply With Quote
Old 03-19-2013, 09:06 AM   #2
Rewards Points: 12,856
Time to test the thermostat and elements.
http://homerepair.about.com/od/plumb...nt_replace.htm
Old 03-19-2013, 09:41 AM   #3
PoleCat's Avatar
Rewards Points: 1,646
Hard water is a death sentence to electric water heater elements. I worked at a place that was so bad that three year old tanks where 1/3 full of sediment. Flushing only removes the small particles. We had to "dig" them out through the hole where the bottem element goes in. An appropriatly sized tube attached to a good shop vac and about an hour out of your life will get most of it out.
PoleCat is online now   Reply With Quote
Old 03-19-2013, 09:45 AM   #4
If it's that bad get the water test to see what treatment is called for.
May need a water softner.
Old 03-19-2013, 09:57 AM   #5
I am on public water. Didnt know it give me issues like this. If i ised a hose with a nozzle on it to flush out the calcium on the cold water tube would it hurt the water heater?
Old 03-19-2013, 10:06 AM   #6
PoleCat's Avatar
The place I was at was on public water too. It was an apartment community so softeners were not standard equipment. (Should have been though) The issue we had with flushing was that it left too much rock behind and the new element was assured to last less than a year.
Electric "point of use" water heater units. Am I wrong? frascati Plumbing 8 02-16-2013 10:28 PM
No hot water at any faucet, water heater working fine rivercliff Plumbing 5 10-27-2011 10:47 AM
Water Heater blowing out Power to Entire House tbigley Electrical 5 03-02-2011 03:54 PM
should I switch from natural gas to electric water heater supermaxhd Plumbing 24 11-28-2010 01:11 PM
Oil fired furnace and hot water heater question steveinpa Plumbing 3 08-10-2010 09:42 AM
