Electric Hot Water Heater - Plumbing - DIY Home Improvement | DIYChatroom
Old 08-07-2007, 12:05 PM   #1
Hi, we had a lower element burn out and that in turn( I think) took out the upper thermostat. I have replaced both and checked the upper element (little bit of scale but pretty clean otherwise). This morning I noticed the over temperature breaker had popped and I had to reset it. Does the bottom thermometer usually fail open or closed and could it be causing the temp to get to hot?
aragogando is offline   Reply With Quote
Old 08-07-2007, 04:16 PM   #2
Journeyman Plumber
Ron The Plumber's Avatar
We always replace both upper and and lower stats, are you sure you got the wires back on the correct terminals?
Fix it right the first time, so you won't have to fix it a 2nd time.
2008 Oregon Specialty Plumbing Codes
Ron The Plumber is offline   Reply With Quote
Old 08-08-2007, 04:27 AM   #3
Long-Time DIYer
Mike Swearingen's Avatar
A tip on replacing water heater tstats (both as Ron said):
1. Memorize or sketch the exact layout and number of screws on the existing tstats, and get a set exactly like them from the store (does not have to be same brand).
2. Exchange the wires ONE AT A TIME from the old to the new tstats to the corresponding screw.
Can't go wrong like that.
A simple way to test elements is to disconnect all wires and test with an ohm meter. No resistance, replace it.
Mike
Mike Swearingen is offline   Reply With Quote
Old 08-12-2007, 10:27 AM   #4
VHI
I had the same problem with my water heater. Replacing both elements and thermostats fixed my problem, even though it was just the bottom element that tested bad. Plumber told me that water was being heated by upper element only which weakened the stat.
victor
VHI is offline   Reply With Quote
new electric water heater - Vacuum breaker necessary? J187 Plumbing 12 05-26-2012 08:42 AM
Electric Water Heater GTSRider Plumbing 31 12-07-2008 11:30 AM
Periodic release from (I think) the T&P valve on the water heater alexz Plumbing 3 08-15-2006 10:31 AM
Draining a hot water heater singforsupper Plumbing 1 06-07-2006 06:01 PM
Electric Hot Water Heater Cooked? bobo Electrical 7 09-09-2005 06:45 PM
