Electric Hot Water On Demand! Is It Good? - Plumbing - DIY Home Improvement | DIYChatroom
Old 03-12-2008, 05:35 PM   #1
Electric hot water on demand! Is it good?
i am building a home in winnipeg canada and have heard a bit about these hot water on demand systems but only about the gas ones. I researched one made by american tankless water heater company. i would purchase the largest model 27kw. i simply am wondering if anyone out there is using this electric system and if they are happy with it .Can you run 2 large draws at once (laundry and shower)? , does pressure keep up? any help amongst this topic would be greatly appreciated.thanks
E-ROCK is offline   Reply With Quote
Old 03-13-2008, 10:06 AM   #2
Rewards Points: 264
http://www.gotankless.com/stiebel-eltron-tempra-29.html
That's the largest residential electric tankless unit I know if. Do a search in this forum for "tankless" and you'll find more information and discussion. I've got an elec. tankless and love it, but our usage is low, electricity is cheap, and I would bet our incoming water temp is warmer than yours. You'll need a minimum 200amp service to install, and a minimum water temp of 45-50F to use two fixtures simulateously. You might check out a larger gas unit if your water temp is too low.
moneymgmt is offline   Reply With Quote
Ice Maker Not Getting Water sgorak General DIY Discussions 3 10-27-2008 08:02 PM
Stumped: Basement water and fix- Did I make things worse? jws3 Building & Construction 27 10-16-2008 07:38 AM
Help! Water Problem no one can solve! Goonky Plumbing 4 12-24-2007 09:03 AM
Sump pit filling with water in dry weather dimitar Building & Construction 13 12-19-2007 11:59 AM
Hot Water Cross Over rjordan392 Plumbing 3 09-11-2007 12:33 PM
