Old 08-11-2012, 10:18 PM   #1
electric hot water baseboard heaters.
I am not sure if this question would fall plumming, but here it goes.
The house that I have resalinty purchased has an electric boiler with hot water baseboard heaters to heat the house. Now I am looking into removing this as it only has 3 zones I think its called. I don't want to have the heat on in all three bedrooms when I am only in one. So to remove it, is it as simple as turning it off draining the water and taking out the pipes and registers?
handyman_squire is offline   Reply With Quote
Old 08-11-2012, 10:22 PM   #2
do you have another heat source also if not might be cheaper to separate the rooms into separite zones then add new heat system
be careful my advice only comes from general knowledge i know about the 4 rules it takes to plumb and they are
1 poop needs to flow down hill. 2 hot on left cold on right
3 i get a pay check on Mondays 4 do not chew finger nails at or after work.
jaydevries is offline   Reply With Quote
Old 08-11-2012, 10:29 PM   #3
We are going to install electec baseboard heaters and later this year a hear pump. The registers that are in the rooms are huge almost the whole length of the wall and in a few rooms take up two walls
Old 08-11-2012, 10:55 PM   #4
so you are removing all water heat so shut off water supply and electric and demo out all of it
Old 08-12-2012, 06:44 AM   #5
biggles's Avatar
where are you located and how are the electric rates in going HP and electric baseboard.might consider using the HP as first stage of heating and the boiler/baseboard as secondary heating stage when that HP goes into defrost
Old 08-12-2012, 07:14 AM   #6
As said before the baseboard water heaters take up way to much room. They go around corners and in some cases 10 feet long. We want baseboard heaters to be able to control each rooms temp.
electric baseboard heaters engraverlady Electrical 5 03-23-2012 06:06 AM
electric baseboard heaters garyjackel1 Electrical 17 12-23-2011 06:49 PM
hot water baseboard flow question (long) fred54 HVAC 4 10-14-2011 04:39 AM
electric baseboard heaters jskeel05 HVAC 2 08-31-2011 07:00 PM
Oil powered Hot Water Radiation with Baseboard Heaters girly_momma HVAC 5 01-13-2010 10:22 PM
