Electric Current System V Salt Water Softener? - Plumbing - DIY Home Improvement | DIYChatroom
Old 01-29-2009, 09:35 AM   #1
Electric current system v salt water softener?
Do the systems that send a low electrical charge through the main feed into the house work as well as a normal system with the big tank and salt etc? If they work I would assume this is the way to go, saves on salt and space in the garage. I am in Florida and I am moving into a new house pre plumbed for a softener. Thanks in advance for any help/info sent my way.
I am looking at this http://www.equinox-products.com/HardnessMaster.htm
and this http://cgi.ebay.com/ws/eBayISAPI.dll...%3DI%26otn%3D2
oasis is offline   Reply With Quote
Old 01-30-2009, 06:16 PM   #2
Ive pulled out alot of those elec. softeners and i can tell you that in my experience they dont work. according to the national water quality assoc. a ion exchange water softener (one that uses salt) is the only softener that actually removes hardness and iron. Dont waste your money and make sure that if you buy a softener it is one that parts are readily available for. aka not a sears or kenmore. stay with a fleck valve or an autotrol valve or if you can find it a clack valve.
lilh2o3 is offline   Reply With Quote
Water Purification System - Maintenance Qs cjcocn Plumbing 1 11-18-2008 07:31 AM
Replacing plumbing system kbsparky Plumbing 5 09-16-2008 09:41 PM
Hot Water Heating System in older house GrannyAnnie HVAC 2 08-31-2008 04:50 AM
(Water Heater MYSTERY) Hot water out from dead tank with cold water in it? Inayity Plumbing 6 07-14-2008 08:36 PM
Water level in boiler system Barefoot Brian HVAC 3 10-19-2006 01:11 PM
