Ele Water Heater - Plumbing - DIY Home Improvement | DIYChatroom
Old 09-28-2013, 11:31 AM   #1
Rewards Points: 20
ele water heater
40 gal ele w/heater. At night, temp. is125. In AM the temp is 95.
Does that mean the upper thermostat is bad?
Thanks Emmy
emmy is offline   Reply With Quote
Old 09-28-2013, 11:58 AM   #2
A "Handy Husband"
rjniles's Avatar
Rewards Points: 4,274
I would suspect the upper T-stat also but I would replace them both.
Coastal South Carolina
Old 09-28-2013, 05:28 PM   #3
Rewards Points: 582
how old is heater....is it worth putting money into....ben sr
water heater drip kdange1 Plumbing 6 10-29-2014 05:26 PM
STATE water heater failures SinCityKid Plumbing 5 05-02-2013 10:22 PM
How to properly drain and flush a hot water heater? speedster1 Plumbing 9 04-17-2012 09:55 PM
A blocked water line causing water to loose heat? Snav Plumbing 6 05-07-2010 02:18 PM
Water heater pressure relief valve confusion Flt_Simulation Plumbing 4 07-11-2009 10:02 AM
