Ejector Pump Help - Plumbing - DIY Home Improvement | DIYChatroom
Old 01-19-2011, 10:02 PM   #1
Ejector Pump help
I have an ejector pump that won't shut off sometimes. So my questions is, the switch that turns the pump on/off, is it a part that can be replaced or is it attached to the pump? I notice two cords coming out of the pit which leads me to believe that its a separate part. Also, is it the same part as a sump pump switch?
Thanks,
Doug
spe464 is offline   Reply With Quote
Old 01-20-2011, 06:23 AM   #2
Sometimes they are repairable, Check manufacturers website for part. But if it has a few years on it, I would replace the whole thing. When one part fails, often more will begin failing.
Old 01-20-2011, 08:35 AM   #3
Owner
LateralConcepts's Avatar
Is this for ground water or sewage? It could be that the float switch is just sticking somewhere or weighted down with solids. Does the cord have a piggy back plug? I would pull the pump, throw it in a bucket, and go test it outside. Plug it in, then lift up the float to see if it shuts off. Don't run it dry for more than a couple seconds.
Brad Penske, Operations Manager - Coeur d'Alene, ID
Lateral
CONCEPTS, LLC - Sewer & Septic Line - Video Inspection, Locating, Consulting
(208) 818-8241
Like us on Facebook!
LateralConcepts is offline   Reply With Quote
Tags
ejector , sump , switch problem
