-   -   Ejector Pump help (http://www.diychatroom.com/f7/ejector-pump-help-92874/)
spe464 01-19-2011 10:02 PM
Ejector Pump help
I have an ejector pump that won't shut off sometimes. So my questions is, the switch that turns the pump on/off, is it a part that can be replaced or is it attached to the pump? I notice two cords coming out of the pit which leads me to believe that its a separate part. Also, is it the same part as a sump pump switch?
Thanks,
Doug
Just Bill 01-20-2011 06:23 AM
Sometimes they are repairable, Check manufacturers website for part. But if it has a few years on it, I would replace the whole thing. When one part fails, often more will begin failing.
LateralConcepts 01-20-2011 08:35 AM
Is this for ground water or sewage? It could be that the float switch is just sticking somewhere or weighted down with solids. Does the cord have a piggy back plug? I would pull the pump, throw it in a bucket, and go test it outside. Plug it in, then lift up the float to see if it shuts off. Don't run it dry for more than a couple seconds.
