Ejector Pump Cycling - Plumbing - DIY Home Improvement | DIYChatroom
Old 09-05-2010, 07:09 PM   #1
I had to replace an ejector pump in my basement that was connected to my washer (no bathroom on lower level). My old pump I think was the original from 1998 and had 2 switches (one went into the other plug) and when it would go off I would hear the hammering sound of the check valve once during each cycle (wash and again in spin) for large loads. Now the new pump (Zoeller) has one plug and I hear it go off 3 times during each cycle. Why is it different? It's a lot quieter but I'm concerned that it's going off so often and that it will burn out quickly? While it goes off 3 times it's realtively quick. Should I be concerned about this?
jend300 is offline   Reply With Quote
Old 09-05-2010, 09:00 PM   #2
the float needs to be adjusted to allow maximum pumping of the basin. Pumps generally have a lifespan of XXXXX # of pumps, its not exact but if the pump is working three times as much there's a good chance of it burning up 3 times as quickly
the_man is offline   Reply With Quote
Tags
ejector , pump running
what's worse - pump cycling or running continuously? rtoni Plumbing 5 06-18-2012 10:06 PM
Blower cycling and vibration whatshappening HVAC 1 02-09-2010 05:48 AM
Goodman & Honeywell Vision Pro Short Cycling tpirovol HVAC 8 12-23-2009 06:55 PM
Problem with Burnham Oil Furnace short cycling Catherine M Brown HVAC 13 01-29-2009 11:58 AM
HVAC Short Cycling Redparis HVAC 2 02-26-2008 11:21 PM
