Ejector Pit Problem - Plumbing - DIY Home Improvement | DIYChatroom
Old 03-05-2012, 10:27 AM   #1
Ejector pit problem
My ejector pump stopped working. I went and bought a new pump and put in. when I nplugged it in I heard gravel going through the pipes and then the new pump stopped. I took the pump out and dumped gravel out of it.The sump pump also had stopped working in a different pit.
Could water pressure under the foundation have caused the ejector pit to break and let gravel in.
andersenwj is offline   Reply With Quote
Old 03-05-2012, 03:50 PM   #2
Ejector pit problem
I would try and elevate the pump off of the bottom of the pit if space allows. You can zip tie the pump to a cinder block or they also make polyethylene pump stands. Gravel is probably not coming in right at the basin, probably fines from the drains that lead into it.
guisertj81 is offline   Reply With Quote
The Following User Says Thank You to guisertj81 For This Useful Post:
jaydevries (03-05-2012)
2 TVs fried: Electrical vs. Comcast Coax Cable Problem LynOprinka Electrical 17 07-16-2012 09:01 PM
Very Strange Shower Drain Problem MattWhite Plumbing 12 05-21-2011 12:53 PM
Don't understand this breaker tripping problem majesticjess Electrical 10 03-05-2010 07:42 PM
Stymied by window leakage problem. Matth3w General DIY Discussions 5 06-11-2008 07:26 PM
Post-Tension Slab Problem Advice/Help Mike McBride Building & Construction 2 01-09-2007 02:51 PM
