Efflorescence In Basement Bath - Plumbing - DIY Home Improvement | DIYChatroom
Old 10-14-2008, 01:07 PM   #1
efflorescence in basement bath
Question I am getting efflorescence coming up from behind my shower wall and from another wall where the basement floor is crumbling up. The bathroom was installed prior to us buying the house. Is it possible that he used the right mix of concrete on the floor when connecting the plumbing underground? or is maybe the waste lines are not connected properly. I have checked behind the shower wall with no evidence of water leaks...I have read of ways to clean it with water and vinegar.....Is there a way to seal the floor or will i have to dig up the floor???????
zoolou is offline   Reply With Quote
Old 10-14-2008, 03:01 PM   #2
Rewards Points: 1,910
Efflorescence is caused by water migrating through the concrete leaching minerals out to the surface. So the first thing you need to do is figure out the source of the water. It may be ground water or it may be from your shower or it may be from your plumbing.
You really don't want to unnecessarily dig up the plumbing and find out it was ok. Is there any way you can not use the bath for an extended period of time? If so clean up the efflorescence, don't use the bath and see if it returns. In the meanwhile carefully check your outside grading and downspouts to see if the water might be coming in from outside.
Old 10-14-2008, 09:15 PM   #3
There is no downspouts where the bathrom(s) are located....It's close to my back door and concrete patio....The upstairs bathroom is directly above the downstairs, thats why i'm wondering when they tied into the wasteline maybe they did something wrong....didnt glue the ABS ..maybe not using any ABS at all????
Wiring for half bath in basement ELurie Electrical 5 08-06-2011 10:06 PM
pre-stubbed basement bath vent needed? ameleus Plumbing 7 09-21-2008 11:26 AM
Bucket in concrete for full bath in basement? Leoskee Plumbing 18 08-26-2008 04:27 PM
Basement 1/2 bath--full bath conversion Demochick Project Showcase 2 06-30-2008 10:03 PM
finishing a basement bath - tie in to ejector pump vent? ajbowman Plumbing 7 04-15-2008 01:09 AM
