Easy way to fix leaks on old brass drains?
Help! I have a leak in the p-trap under my tub and another leak from the overflow on the tub. I'm pretty sure it's brass. Is there an easy and not so costly way to fix these myself? I've worked a bit with ABS and copper supply pipes before but not this. Photos are below.
Can I clean it up, empty the p-trap and solder around it? But in any case, for the overflow, I definitely would not be able to reach it from behind. Someone on Yahoo Answers suggested this: Quote:
https://lh3.googleusercontent.com/-b...+Version+2.jpg https://lh3.googleusercontent.com/-x...9+00.15.21.jpg This is a view from the bottom of the tub. At the top is the overflow drain that is leaking -- you can see the wet strip going down the outside of the tub. |
There is no fixing that, time to replace the whole thing.
Yep--that's a soldered copper P-trap----
You should be able to replace the entire drain set and P-trap from below--- A solvent weld set might be easier than one with compression fittings. |
Ok I guess I can check with Home Depot and figure out how to transition to ABS or PVC so I can solvent weld in a new p-trap ...
Any ideas on the overflow drain that is up higher and in a tight space only reachable by one hand? |
looks like the overflow just needs a new rubber washer and if you clean the joint really good on the trap it could be resoldered. i have done it many times. the epoxy that someone mentioned would work also but you still have to get it clean.
I'll go with the waterweld epoxy putty too for the p-trap since it's hard to reach the other side of the pipe. But good to know I could also resolder as an option. Thanks very much for your help! |
| All times are GMT -4. The time now is 11:05 PM. |
