Easy Water - Plumbing - DIY Home Improvement | DIYChatroom
Old 09-21-2010, 05:05 PM   #1
SparkySparks's Avatar
Easy Water
Our icemaker has failed twice in 3 years we believe because the water is hard. We want to buy the Easy Water system for our home. Any comments?
www.easywater.com
SparkySparks is offline   Reply With Quote
Old 09-21-2010, 07:00 PM   #2
Licensed Master Plumber
Read this and then get back to me
http://www.chem1.com/CQ/magscams.html
I can go on and on for pages with the reasons why easy water and it's ilk do not work and can not work but most of the information is on that guys site.
Always ask to see your contractors license!
NHMaster is offline   Reply With Quote
Old 09-22-2010, 11:36 AM   #3
easy water info
Thanks for the link...I suppose I'm back to square one now.
Old 09-22-2010, 09:38 PM   #4
www.easywater.com
Before a suggestion can be made, more info must be given. What do you mean "failed"? What are your water conditions, city, well, etc.? Do you have any water treatment?
Andy CWS is offline   Reply With Quote
Old 09-23-2010, 12:02 AM   #5
lloydb's Avatar
I've worked for both Rainsoft and Culligan dealers and personally, I don't believe Easy Water's claims.
I don't have any stock in Culligan, I was just a service and install guy, but water treatment is serious business to them. The dealership I worked at had D.I. water regeneration, a water bottling plant, commercial and residential softeners, Reverse Osmosis etc.
The point I'm getting to is that they know their water. If there was something you could wrap around a pipe to counter the effects of hard water, they'd be front and center. If it worked, Culligan would be selling it.
Btw, If you are just trying to keep hard water out of your icemaker, An undercounter R.O. would do the trick. You could probably get one and put it in yourself for $200
Broken Arrow hvac Broken Arrow Air Conditioning
lloydb is offline   Reply With Quote
The Following User Says Thank You to lloydb For This Useful Post:
NHMaster (09-23-2010)
Old 09-23-2010, 01:20 PM   #6
Easy Water?
The icemaker's internal device became clogged with what appears to be calcium buildup, I can see the same buildup around my shower head & copper fittings, but not so much on brass fittings.
My refrigerator has a filter cartridge for the drinking water & I believe the ice maker as well.
My main question is "does anyone believe in "EasyWater.com"'s claims?
Old 09-30-2010, 04:26 PM   #7
Here is a picture of the plumbing underneath our kitchen sink. This is why we are considering Easy Water to eliminate the minerals that we believe are the source of our troubles.
Our plumber thinks we have an electrical ground problem, possibly. Remember this buildup mainly occurs on the copper fittings in our home, not the brass connections so much.
We had 2 slab leaks and 2 leaks in the walls that occurred in the copper pipes for no apparent reason in the last 3 years. Our home is 10 years old.
The 2nd photo is the piece of copper pipe that had a pinhole leak in it from under the slab of our home. It has a burgundy tint to it but we don't know why. The plumber does not know why the pipe failed. Maybe faulty pipe from the manufacturer, maybe soil interaction, maybe the bad electrical ground he suspects is causing all of our troubles.
Old 09-30-2010, 08:20 PM   #8
Rewards Points: 1,570
I see no way it could work; akin to alchemy to change lead into gold. Might read:
http://advice.thisoldhouse.com/showthread.php?t=5152
bob22 is offline   Reply With Quote
Old 09-30-2010, 08:28 PM   #9
[quote=SparkySparks;509398]Here is a picture of the plumbing underneath our kitchen sink. This is why we are considering Easy Water to eliminate the minerals that we believe are the source of our troubles.
First of all, EasyWater is junk. Now that got that out of the way let's review what you are considering. EasyWater's claim is to prevent scale build up IN not ON pipes. Looking at the build up, one might ask, How in the world would water traveling 'through' the pipe cause build up on the outside of the pipe?
Again, if you can SEE it, it isn't caused by water flowing through the pipes. Your plumber probably know what he is talking about.
Sure there must be a reason. Corrosion. Corrosion can be cause by electrolysis by not grounding pipes or having electric wires coming into contact with plumbing. It can also be caused by dissimilar metals coming into contact. There are other ways copper can corrode. More likely, it is acidic water. What is you pH?
"Pinhole leaks" this is corrosion not the opposite, which would be scalebuild up. So if Easywater actually did what they claim to do--remove scale build up--then your plumbing would corrode even more. Therefore, that last thing you want is someething to make the copper even more prone to corrosion, right?
In fact, a little scale build up would be beneficial to your plumbing. The negligible lose of flow due to a very minor scale build up is more than offset by the preservation of the plumbing by not getting all eaten away..
Low hot water pressure crebive Plumbing 38 02-26-2013 01:26 AM
How to properly drain and flush a hot water heater? speedster1 Plumbing 9 04-17-2012 10:55 PM
water pouring into basement from around water supply line matty8199 Building & Construction 29 12-29-2009 06:07 PM
Very Low Hot Water Pressure. PAS1970 General DIY Discussions 2 02-25-2009 04:01 PM
Is 1/2 Pex more restrictive than 1/2 copper? twilightcall Plumbing 19 06-24-2008 08:32 AM
