Easiest Question I Don't Know The Answer To - Plumbing - DIY Home Improvement | DIYChatroom
Old 07-25-2012, 03:34 PM   #1
easiest question I don't know the answer to
I am putting a basket in the new sink the question is how tight do I tighten the lock nut under the sink? tight /very tight/ python death grip. I have turned it quit a few times seems like it can go more but I wonder if I could over tighten?
I have this big wrench that gets a real solid grip and it has a long handle lots of leverage ....
thanks
petros151 is offline   Reply With Quote
Old 07-25-2012, 04:13 PM   #2
Lightfoot's Avatar
Rewards Points: 272
tight enough that it doesn't leak
J/K pal. I don't know the answer either but i'd think it wouldn't be necessary to really crank on it.
Lightfoot is offline   Reply With Quote
Old 07-25-2012, 04:31 PM   #3
OK but I was hoping to avoid having it leak! I"ll take it out in the yard and test it before I install the drain and faucet
Old 07-25-2012, 05:08 PM   #4
DIY staff
Rewards Points: 7,174
You did add plumbers putty under the rim?
Often you need to tighten--then wait a minute for the putty to squeeze out a bit--then tighten it one more time---Python grip --no--tight--yes---
Old 07-25-2012, 05:49 PM   #5
yes I did putty it and I did notice that after tightening and waiting it would spin a little more. I stopped after it felt good and tight and I did just set the sink in the tub and put the strainer in to stop the water and it did not leak so I"m set
thanks
The Following User Says Thank You to petros151 For This Useful Post:
oh'mike (07-25-2012)
Simple question I can't find the answer to Richo Plumbing 7 07-17-2011 10:20 AM
Bath paint 6 choices suggestions User24 Interior Decorating 5 01-18-2009 11:08 PM
simple question needs answer stacy97 General DIY Discussions 6 09-21-2008 06:02 PM
Basement Renovation Question KUIPORNG Remodeling 234 08-26-2008 08:19 AM
hrv question indep HVAC 3 07-17-2008 10:39 PM
