-   -   easiest question I don't know the answer to (http://www.diychatroom.com/f7/easiest-question-i-dont-know-answer-151516/)
petros151 07-25-2012 04:34 PM
I am putting a basket in the new sink the question is how tight do I tighten the lock nut under the sink? tight /very tight/ python death grip. I have turned it quit a few times seems like it can go more but I wonder if I could over tighten?
I have this big wrench that gets a real solid grip and it has a long handle lots of leverage ....
thanks
Lightfoot 07-25-2012 05:13 PM
tight enough that it doesn't leak:laughing:
J/K pal. I don't know the answer either but i'd think it wouldn't be necessary to really crank on it.
petros151 07-25-2012 05:31 PM
OK but I was hoping to avoid having it leak! I"ll take it out in the yard and test it before I install the drain and faucet :brows:
oh'mike 07-25-2012 06:08 PM
You did add plumbers putty under the rim?
Often you need to tighten--then wait a minute for the putty to squeeze out a bit--then tighten it one more time---Python grip --no--tight--yes---
petros151 07-25-2012 06:49 PM
yes I did putty it and I did notice that after tightening and waiting it would spin a little more. I stopped after it felt good and tight and I did just set the sink in the tub and put the strainer in to stop the water and it did not leak so I"m set
thanks:thumbup:
