Easier Way To Redo Silicone Caulk Around Tub? - Plumbing - DIY Home Improvement | DIYChatroom
Old 09-12-2011, 10:31 AM   #1
Rewards Points: 682
Easier way to redo silicone caulk around tub?
I've had to chip off and replace that silicone seal between the tub and wall tiles a couple of times (because of ugly mold growth in the silicone), and I've found it to be extremely time wasting. I've tried a couple of caulk removing products but they've all been useless. Have you guys found any products that can remove silicone caulk without damaging the plastic or tile surfaces?
darsunt is offline   Reply With Quote
Old 09-12-2011, 10:36 AM   #2
Sharp,single edge flat blade razor blade...several hours & a few cold beers.
Marbledust is offline   Reply With Quote
Old 09-12-2011, 10:45 AM   #3
Tileguy
Bud Cline's Avatar
Rewards Points: 558
If you are having to (literally) "chip" it off then it isn't silicone. Until you can determine what it is or use the correct terms then there is little anyone can do to help.
Marbledust has offered your best solution.
XXX
Old 09-12-2011, 08:25 PM   #4
Lightfoot's Avatar
Rewards Points: 272
I agree. and a radio tuned to your favorite station helps the time go by too. It's a tedious, aggravating job, and i haven't found a quick way to do it either. Might as well get comfy and enjoy yourself!
Lightfoot is offline   Reply With Quote
The Following User Says Thank You to Lightfoot For This Useful Post:
Marbledust (09-15-2011)
Old 09-14-2011, 09:20 PM   #5
Rewards Points: 682
I did it. I hate it. Took forever, but done now.
There has GOT to be a better way
Old 09-14-2011, 10:07 PM   #6
Tileguy
Bud Cline's Avatar
Rewards Points: 558
Old 09-15-2011, 08:53 AM   #7
Rewards Points: 290
The razor blade, cold beer, and good music is probably the best advice. However, when you re-silicone, use mold resistant stuff..AND if you do get some mold, don't wait until it becomes a big problem. Keep your tub clean with bleach every once and a while, and you will never have to do this ugly job again. You know the old saying 'A stitch in time, saves nine"
polarzak is offline   Reply With Quote
The Following User Says Thank You to polarzak For This Useful Post:
Old 09-15-2011, 11:50 AM   #8
Rewards Points: 93
I too spent a good amount of time doing this. I started searching for a better way and found the thread below.
http://www.diychatroom.com/f2/recaul...r-frame-15069/
Not sure if it will work, but I will try his cleaning formula next time when I see mildew in my shower.
leungw is offline   Reply With Quote
Old 09-15-2011, 02:43 PM   #9
JOATMON
ddawg16's Avatar
Rewards Points: 1,454
Brings up a good point....cost factor for projects.....it's not just the material but how much beer, chips and salsa it takes to complete the job.
mold on silicone caulk in shower gibi Plumbing 6 05-07-2011 10:26 AM
Silicone caulk ArleneHolli Painting 1 10-25-2010 09:50 AM
How to Clean Up Caulk Mess on Driveway Left By Construction Crew ToolbeltGal Building & Construction 6 09-25-2010 04:36 PM
painting over silicone caulk momof2labs Painting 6 09-17-2010 06:28 PM
Silicone Caulk Removal Gary Osterberg General DIY Discussions 2 09-14-2010 01:01 PM
