DWV System - Plumbing - DIY Home Improvement | DIYChatroom
Old 08-05-2009, 08:11 AM   #1
DWV system
I'm remodeling a bathroom in our house. The old dwv pipe is black Shed. 40. Can the new white pipe be used in connection with this? Are they compatible to be glued together? Seems to me they'd be the same but I don't want to find out the hard way either.
Thanks,
Pat
P2lman60 is offline   Reply With Quote
Old 08-05-2009, 09:57 AM   #2
Rewards Points: 150
Use transition glue. http://www.oatey.com/Plumber/Shared/...en+Cement.html
James Con is offline   Reply With Quote
Old 08-05-2009, 11:55 AM   #3
No hub
If it were me, I would NOT use the transition glue because the PVC (white) and ABS (black) pipes have different expansion and contraction rates, which is likely to cause the connection to crack over time. Also it may or may not be legal to use this product. Not all jurisdictions allow it, however some do.
If I had to connect the two different types of pipe, I would suggest a no hub connection.
Also these no-hub connectors are supposed to be torqued to an exact specification. They sell a special wrench just for these connectors. You dont want to over or under tighten these as this may cause it to fail (leak!)
You can get these at any hardware or plumbing supply store. Big Box stores have them as well.
Last edited by zenman; 08-05-2009 at 03:29 PM. Reason: change "no hub" picture link
zenman is offline   Reply With Quote
Burnham Series 2 Cast Iron Radiator System SybrDave HVAC 2 12-10-2009 05:24 AM
Hot Water Heating System in older house GrannyAnnie HVAC 2 08-31-2008 04:50 AM
New House, new system, poor cooling Faulknertw HVAC 15 07-08-2008 10:06 PM
boiler / Over-pressurizing cparke HVAC 1 05-21-2008 05:54 AM
Size A/C system properly 70stang HVAC 1 03-26-2006 07:22 PM
