DWV System - Plumbing - DIY Home Improvement | DIYChatroom
Old 08-23-2012, 07:06 PM   #1
DWV System
I just got a 2nd floor addition. Im running low on my budget and now I have to do the plumbing myself. Im allowed to pull my own permit because its my house. My house currently has the first floor bathroom sink, toilet, and bath tied into the 3" vertical stack/vent in the middle. Therefore after some code reading, I think its easier to redo the plumbing in both bathrooms. I am located in PA. Is this a good plan for DWV to get a permit?
sloojoe is offline   Reply With Quote
Old 08-23-2012, 07:46 PM   #2
DIY staff
Rewards Points: 7,174
DWV? what does that mean?
Old 08-23-2012, 07:50 PM   #3
drain-waste-vent (or DWV) is part of a system that removes sewage from a building and regulates air pressure in the waste-system pipes
Old 08-23-2012, 07:52 PM   #4
Plumber
TheEplumber's Avatar
Rewards Points: 792
Drainage,Waste & Vent
Do you have to submit a drawing?
Old 08-23-2012, 07:59 PM   #5
yes. I did it real quick with Photoshop. I want to know if that was the best layout to drain and vent. This is the current DWV layout of my house.
Old 08-23-2012, 10:14 PM   #6
Master Plumber
Javiles's Avatar
Rewards Points: 996
if your under the IPC that Lay out wont fly.
Experience is Knowing what to do next, Skill is knowing how to do it
http://www.americandrain.net
Javiles is offline   Reply With Quote
Old 08-23-2012, 10:39 PM   #7
Plumber
Rewards Points: 792
Won't fly with UPC either. One reason is the upper floor fixtures cannot drain into a vent
Old 08-24-2012, 07:33 AM   #8
Rewards Points: 3,130
Where is an upper floor fixture draining into a vent? Looks to me like they all drain to the main stack.
Old 08-24-2012, 10:08 AM   #9
retired elect/hvac/plumb
plummen's Avatar
Location: south east of omaha/The island of misfit contractors
Rewards Points: 2,020
Which is being used as a vent unless you revent the fixtures above flood level of highest fixture
"facts" have no relevance to this discusion
Posting from a concrete bunker under a non descript barn
plummen is offline   Reply With Quote
Old low voltage lighting system - switches stopped working. zepman Electrical 14 02-17-2016 07:18 PM
Electric Run, Voltage Drop Issues. Eventual upgrade of system this year. lawnphysics Electrical 4 04-06-2011 06:24 PM
Need to bleed a hot water baseboard heating system Brewmaster HVAC 4 02-17-2011 07:04 PM
Need advice RE: purging air from baseboard hot water heating system mikenri HVAC 2 01-19-2011 07:17 PM
beware humidity system? Emaderton3 HVAC 5 02-10-2010 11:52 PM
