DWV Remodel. Can I Do This With My Main? - Plumbing - DIY Home Improvement | DIYChatroom
Old 03-19-2011, 10:29 AM   #1
DWV remodel. Can I do this with my main?
I have a 3" horizontal main running under my slab floor with the toilet at the end of the line. I am now moving my toilet downstream 8 feet. The existing lav ties into the main down stream from where the old toilet location was located. With the new location of the toilet, the existing lav will now tie into the main upstream from the toilet. I plan on leaving the old main active upstream from the toilet to keep the existing lav tie in. The question is, does the possibility exist of some waste back flowing up the main to where I have the existing lav tied into? The pitch on the system is correct and I would expect water from the lav to help wash down any waste that back flowed up the main to where the lav ties in. Any thoughts??? Thanks
antalamo is offline   Reply With Quote
100AMP Main board off a 100AMP Main Fuse cmarcus3031 Electrical 18 03-19-2014 11:17 PM
Help? re replacing valves (main & toilet) iya Plumbing 2 06-14-2010 05:54 AM
Main bathroom remodel MagicalHome Remodeling 4 06-02-2010 07:44 PM
Replace main panel? And lots of other ?s Bcoleman6 Electrical 13 01-22-2008 10:40 AM
Main Breaker won't stay on Please Help mikpowl Electrical 8 01-10-2008 10:22 AM
